  • Guests: 49
12/25 Kolas (18)
12/26 buxtronix (50)
High temp plasics?
Ben Solon
Mon Nov 18 2013, 12:02AM Print
Is anyone familiar with machinable plastics(or other materials) that are moisture resistant and have no deformation or loss of rigidity up to 100C? I've looked at fiberglass, but when machined, the swarf(or equivalent) can be nasty to breath in or have floating around. PTFE and HDPE both get a bit soft IME. A ceramic would be ideal, but I don't have the capability to machine it, plus It's not a shock resistant as I might like. Any Ideas?
-Ben
Billybobjoe
Mon Nov 18 2013, 01:08AM
Billybobjoe Registered Member #396 Joined: Wed Apr 19 2006, 12:55AM
Polycarbonate?
See here: Link2 You can narrow the temperature range on the sidebar. They have about 45 different types rated for >100C. Some are considerably more expensive than others, so if you have any more details about what you're using it for we could help narrow it down.
Mon Nov 18 2013, 02:18AM
have you considered epoxy? perhaps a type that machinable or even cast-able.
BigBad
Mon Nov 18 2013, 02:28AM
Yes, epoxy, and if you want a composite, epoxy reinforced with kevlar might be reasonable
Mon Nov 18 2013, 11:15AM
Fiberglass could always be machined while you put water/coolent over the tool, meaning that the dust doesnt go anywhere.
BigBad
Mon Nov 18 2013, 02:21PM
Fiberglass isn't that bad to drill anyway. Unlike asbestos it gets cleared from the lungs by the body, partly because the fibre size is controlled during manufacture.
Kizmo
Mon Nov 18 2013, 02:37PM
Polyether ether ketone (PEEK) is the ultimate choice for high temperature and strength applications.
And its not too bad to work with either. May be little bit difficult to find but at least i was able to order some from local industrial plastics seller.
Mon Nov 18 2013, 03:12PM
Nylon, polyimide (Kapton)?
Mon Nov 18 2013, 03:33PM
I'm not sure about the temp on Kydex, but it's strong....
Tony Matt
Mon Nov 25 2013, 05:06AM
Epoxi reinforced with fiberglas.
It could be easily moulded, not nescessary machined .
