  • Guests: 36
OiD (38)
jolty (50)
Baran (29)
10/16 Sanchez (36)
10/16 Knarvel (13)
Filament lamp lit with one wire
GeordieBoy
Tue Nov 12 2013, 01:38PM Print
The 28V 60mA filament lamp has two 50mm long wires soldered to it. It illuminates to full brightness with only one wire connected to the breadboard. The remaining wire is left disconnected.
1384263083 1232 FT0 Dsc 0357
1384263082 1232 FT0 Dsc 0358
1384263083 1232 FT0 Dsc 0359
I thought 4HV readers might find this ammusing, as it initially appears to go against what we are taught about circuits having to be "complete" in order to work. Although I'm sure many of you will have seen it before, and know how it works...? wink
Best regards,
-Richie Burnett,
BigBad
Tue Nov 12 2013, 04:27PM
I was toying with the idea of doing something vaguely like that with my christmas tree, I've simulated it in LTSpice, but I haven't built anything.
Ben Solon
Tue Nov 12 2013, 11:27PM
I really wish 4hv would add some sort of thumbs up so that I can say "This post is awesome" without having to come up with something to post with that.
But while i'm at it: how much charge is moved to/from that wire on the other end of the bulb? It can't have more than a pF or two of capacitance, what frequency do you use to drive it? I can't read the crystal tongue
GeordieBoy
Wed Nov 13 2013, 12:03AM
The lamp is lit by the current flowing through it that charges and discharges the remaining wire that isn't connected to anything. As you said this floating wire will only have a capacitance of a couple of pico-farads at most.
The operating frequency is 25MHz. A CMOS crystal oscillator module drives a Class-C amplifier consisting of a modern equivalent to the 2N3053 NPN biploar transistor. This driver stage serves only to provide enough gate drive power for an IRF510 MOSFET PA stage. The MOSFET also operates in Class C and drives a series resonant load network.
The voltage at the mid-point of the load network rings up to a hundred volts or so with a frequency of 25MHz. This combination of high voltage and high frequency is sufficient to drive a significant current through the lamp to cyclically charge and discharge the few pf of capacitance of the wire the other side of the lamp.
RF engineers can think of the series resonant network as an L-match network between the PA transistor and the lamp load. The lamp with one lead flying presents a load that is resistive in series with a large capacitive reactance. The L-match network transforms this "difficult to drive" impedance to something much lower and real that the PA can drive power into.
-Richie,
BTW, The IRF510 is massively over-spec'd for the trick of lighting up that little bulb! You can actually dispense with the MOSFET PA altogether and get it to light almost as brightly using just the bipolar stage alone.
