  • Guests: 47
Blocking malicious or annoying websites
Hazmatt_(The Underdog)
Mon Nov 11 2013, 05:24AM Print
Hi guys,
I'm no genious when it comes to network setups, so I was just wondering what tactics you would employ to block or deny access inbound to your system from a website that is giving you problems.
My problem description: Yes, I still use AOL, say what you want, I don't care, ...the problem is when I open my mail box, a malicious web site loads, "www.atdmt.com", and gets in my way.
I have set up all I can on my computer to deny it access, and my last hope is to deny it inbound access through the router, I guess...?
It would be easy to do on the old Linksys router....which I was real happy with, except for the fact that my Mom/Brother have to screw with everything, so now we have this POS "Tenda" router, and it's a hassle to deal with.
So, I was just wondering what you guys do, outside of setting up the router. If that's my only option, that's fine too, I'll work with it if I have to. This "www.atdmt.com" site is a real bastard to block.
Andy
Mon Nov 11 2013, 07:32AM
Hi Hazmatt_(The Underdog)
If you use firefox, you could download noscript, and not select to open stuff from them.
You could find the host.txt on your computer and enter there url in there to block it.
the_anomaly
Mon Nov 11 2013, 10:45AM
the_anomaly Registered Member #19 Joined: Thu Feb 02 2006, 03:19PM
Hi Hazmatt,
Try using GRC Shields up
It can show you if you have any open ports on your computer.
PSCG
Mon Nov 11 2013, 01:07PM
PSCG Registered Member #3792 Joined: Sun Mar 27 2011, 06:07PM
The simplest way is what Andy says: use the hosts file to block the connections, along with NoScript (or ScriptSafe if you are using a chromium - based browser). You can download a ready - made hosts file that includes most of the known maleware, adware and other similar sites here.
Tue Nov 12 2013, 02:08AM
Thanks for your input guys. I'll try to see if I can block it completely with the host file suggestion.
I did a search on my computer and it didn't turn up anything. It seems that this site is very invasive to others as well.
dingo27
Mon Dec 09 2013, 06:20PM
dingo27 Registered Member #890 Joined: Tue Jul 10 2007, 10:06PM
well...
i am a bit later, but try adblock and add whole site there (works with new opera, chrome, firefox... )
also opera (12.xx version, not new one) had blocking feature, which worked similar way, new one does not.
also, if you are little bit familiar, try to search what are you looking for , i cannot be more specific, but for example if you are using some application, there may be some setting like load this page at startup ini file... and so on.
Antivirus with firewall could also help.
Shrad
Mon Dec 09 2013, 06:49PM
malwarebytes anti malware
Wed Dec 11 2013, 05:22AM
I added the host site names for the atdmt to the host file, and on re-start it worked fine!
So.. it's working so far. It's just re-directing that site to the local host..which is nowhere. I don't even get blank pop-up windows, so I'm glad it's working for now.
Course...they'll probably come up with some new Java script to hijack my computer again... bastards.
tobias
Thu Dec 12 2013, 02:53AM
tobias Registered Member #1956 Joined: Wed Feb 04 2009, 01:22PM
If you use only mail / websites / eagle, try running any _unix.
Shrad
Thu Dec 12 2013, 08:28AM
clever use and weekly cleaning is the key
avast antivirus, malwarebytes anti malware, and CCleaner is all it takes for being protected well enough under windows
