  • Guests: 25
09/29 Ultra7 (55)
09/29 uitvinderalex (37)
09/30 Terrorhertz (16)
Advise my bridge design?
Ben Solon
Tue Nov 05 2013, 12:20AM Print
Hello again,
I have two is621k40 igbt's that I have to put to use. Designing a low inductance bridge with this much distance between the terminals is difficult, but this is what I've come up with:
1383610479 3900 FT0 Bridge Cad Iso
The two holes in the center are for the terminals of the dc bus capacitor. Would it be more beneficial to move the igbts farther apart to fit the bus cap between the snubbers or just mount the cap above the snubbers with thick copper roundstock standoffs that carry current into the laminated structure?
The entire bridge operates around 40khz and the snubbers are 5uF each, so even with a slight addition to the ESR of the bus cap, the 10uF worth of snubbers should carry a decent decoupling capability...
This is where the problem lies:
1383610787 3900 FT0 Bridge Cad
