  • Guests: 49
Calculating a tesla coil's resonant frequency?
1 2 3 4  last
StormInABottle
Wed Oct 30 2013, 08:25PM Print
StormInABottle Registered Member #9252 Joined: Fri Jan 04 2013, 06:27AM
The tesla coil is 12 inch wide and 12 inch long (Yes that is written right)
And wound using 26 gauge wire.
What would the resonant frequency be?
Also it would be a CW SSTC
Hazmatt_(The Underdog)
Thu Oct 31 2013, 01:57AM
Are you guys really that lazy?
Building Tesla Coils does require that you put in effort, and almost everything you want to know is here, including calculating LTR values!
Do the work.
redruM69
Thu Oct 31 2013, 02:50AM
redruM69 Registered Member #31557 Joined: Tue Aug 06 2013, 02:38AM
I'll be a little kinder. Assuming no topload, about 141khz.
twist2b
Thu Oct 31 2013, 10:57PM
twist2b Registered Member #2086 Joined: Tue Apr 21 2009, 02:33AM
Just out of curiosity, WHY WOULD YOU WANT A 1:1 RATIO?! That's crazy and lossy. You are not building a tesla coil are you?
Fri Nov 01 2013, 10:41AM
JAVATC. If you know how to use it, you get very accurate result. The lambda/4 method gives very inaccurate results, just a "ball park" value.
StormInABottle
Mon Nov 11 2013, 01:44PM
Twist.
I am going to build an SSTC..
But i just want the lowest resonant frequency possible.. Less than 100khz..
DrDarkCurrent
I use tesla coil CAD 2.0
I might just also use piratebay to grab a tesla map version.
Mon Nov 11 2013, 03:46PM
StormInABottle wrote ...
Twist.
DrDarkCurrent
Well, if you want the lowest fres possible, you are using the wrong wire. For lowest fres possible, use the smallest wire you can find. I would recommend 30-34AWG. 34 AWG is very thin, but still manageable.
twist2b
Mon Nov 11 2013, 04:20PM
If you want low resonance like EVS said use higher AWG, but don't go to 34... after 30 it starts getting lossy... Here is a graph that gives you an idea of how to improve your secondary to have low frequency and not be lossy due to skin or proximity:
16 Am
loneoceans
Mon Nov 11 2013, 05:06PM
twist2b wrote ...
16 Am
That's an interesting graph. Twist2b, where did you get that from? Is it part of a larger document?
StormInABottle
Mon Nov 11 2013, 07:57PM
Isn't 30 awg too thin for a cw sttc running at ~6000/8000 watts?
1 2 3 4  last
