  • Guests: 36
12/06 Dago (37)
12/06 Z28Fistergod (39)
12/06 JonIverson (45)
Is There any Place To get A pole Pig For Cheap (Under $600 USA)
MR-ZAPPY
Wed Oct 30 2013, 10:28AM Print
MR-ZAPPY Registered Member #16018 Joined: Fri May 03 2013, 07:19PM
I have always wanted a Pole Pig but I have not found any place that has them for cheap (including ebay) I do not live near a junkyard and am hoping you have some ideas.
PS I have a 20 Amp 240 volt breaker what ballast should I use for that
Wed Oct 30 2013, 12:50PM
I somwhat doubt youll find one, a good idea (im thinking of doing it myself) buy some large ferrite blocks, build them into a large core, wind your own and build a driver with some IGBT bricks.
From what ive seen, polepigs can be very hard to find, atleast, in the USA its much more possible then in the UK (the company also disposes of all their transformers inhouse)
zippotix
Fri Nov 01 2013, 10:14AM
zippotix Registered Member #5208 Joined: Thu Jun 07 2012, 06:12PM
I think finding a potential transformer would be easier and power output is similar to pole pig. You still have to ballast it.
Or, you could wind your own 50hz transformer, like bjtaudio did. His transformer is a beast.
Fri Nov 01 2013, 10:29AM
zippotix wrote ...
the big problem with that is finding the core, i dont know how it is in america, but Iron Cores are hard to find, and likely very expencive.
I follow the ferrite route due to weight and efficiencey, but also because if winding your own, it always means more turns per volt, saving on cost, Ferrite is also easier to find:
Im saving up for 16 of those to build a large transformer.
Fri Nov 01 2013, 04:52PM
PS I have a 20 Amp 240 volt breaker what ballast should I use for that?
The ballasting would, of course, depend on what you want to use the pole pig for.
Just posting a question like that might give considerate people doubts about helping you to get a pole pig.
Ash Small
Sat Nov 02 2013, 11:17AM
__=|(:3)-|--{__ wrote ...
That should give ~7.5kW, I think, but 'may' present some cooling problems.
Sat Nov 02 2013, 11:08PM
Ash Small wrote ...
How so?
