  • Guests: 19
  • Most ever online: 441
    Guests: 441, Members: 0 on 01 Oct : 16:32
TwirlyWhirly555 (33)
10/03 TwirlyWhirly555 (33)
10/04 Michael W. (36)
10/05 GhostlyFigures (36)
FB transformer cores
Ben Solon
Mon Oct 28 2013, 10:44PM Print
Hi,
Does anyone know where to find gapped ferrite cores with bobbins suitable for flyback smps use? I've seen countless ee cores, but never any ones that specify an air gap. I also need to be able to buy them in very low quantities. Power is 15-30 watts.
thanks.
Tue Oct 29 2013, 08:53AM
if you get a general EE core, then just grind it down to the correct airgap needed?
Ash Small
Tue Oct 29 2013, 09:13AM
What size do you need?
RS list some, for example Link2
A place I used to work at used to buy them in small quantities, I think they were generally Epcos ones. I'm not sure if they were ground by Epcos, or a third party.
johnf
Tue Oct 29 2013, 07:03PM
Buy ungapped cores and shim them with stiff plastic to get the required inductance. All SMPS designers do this to get the final design right before ordering a specific gap to be ground from the makers.
The shimming doesnt make any difference except for a little more radiated EMI because of the disconuity in the flux loop around the outside of the core
Ben Solon
Tue Oct 29 2013, 10:01PM
Ash: just what I needed
I've gapped EE cores before, both by grinding and by shims. Grinding Isn't accurate unless you buy or create a specialized rig- which I won't do for a one-off. Shims tend to be able to compress and increase inductance/reduce energy storage by not so insignificant amounts.
