  • Guests: 21
  • Most ever online: 441
    Guests: 441, Members: 0 on 01 Oct : 16:32
TwirlyWhirly555 (33)
10/03 TwirlyWhirly555 (33)
10/04 Michael W. (36)
10/05 GhostlyFigures (36)
Pumpkin lamp ideas
Sun Oct 27 2013, 02:42PM Print
Hi all.
Just remembered that I have four of those "bargraph" orange neon tubes.
They need 140V at 1-12mA to work, so the plan is to use a flickering LED as the
driver and some sort of stepup.
Has anyone else on here used these tubes?
Kind regards, -A
radiotech
Sun Oct 27 2013, 06:10PM
Neon planar would make a good bright display but 140 volts, sourced from mains, inside
a wet pumpkin likely to be touched by kids is a bad idea. Do the whole thing up powered
by a small SLA battery and an inverter inside the pumpkin.
Sun Oct 27 2013, 11:07PM
Might try using a slightly modified CCFL inverter, rewind the secondary and connect a resistor to each transistor base to PWM the output.
Thanks!
-A
