  • Guests: 60
Searching for MICA capacitors
Intra
Fri Oct 11 2013, 10:40AM Print
Intra Registered Member #2694 Joined: Mon Feb 22 2010, 11:52PM
It's a lot of time I spend looking for this stuff. 10-20nF and 1-2uF on 20-25kV and few hundred rms-current. ebay's few lots of SP 2550 is not enough for my project, so I decided to put up for discussion, where or how I or we, if you wish too, can find high-current mica? If it isn't available in retail and no one else produces it anymore, perhaps, it possible to order factory custom batch? Eurofarad, Thomson capacitors or something. Does anyone thought about this?
Fri Oct 11 2013, 11:10AM
Those are really extreme capacitances, such caps will be monstrous. You can search for K15U russian ceramic caps.
Intra
Fri Oct 11 2013, 11:52AM
Dr. Dark Current wrote ...
But, yeah. I need the monsters like that. Something like mmc DR6 of Pslawinski or like mmc Gigantor.
Point is, I want to use big polyphony on DR with analog audiointerrupter. Not midi, where poly is under digital control but distortion guitar audio, with full pack of 6-string chords subgarmonics. I doubt CDE 940C mmc can handle this. Work mode with duty cycle too far of recomended 5%.
Fri Oct 11 2013, 03:45PM
You can email them to get a discount if you are buying more. I got a great deal buying 5.
Intra
Sun Oct 27 2013, 02:55PM
Mads Barnkob wrote ...
I found I=<5000Apeak in data sheet, but can't find Irms value. Do you know Irms value of this caps?
