  • Guests: 32
OiD (38)
jolty (50)
Baran (29)
10/15 OiD (38)
10/15 jolty (50)
10/15 Baran (29)
Robotics power supply questions
U4R1A
Sat Sept 21 2013, 10:53PM Print
U4R1A Registered Member #3505 Joined: Sun Dec 12 2010, 06:03AM
I have a project in which I'm using ~30 smart servos http://www.robotshop.com/content/PDF/manual-drs-0101.pdf. These servos can pull about half an amp when they are in full swing. Since this is a desktop toy I'm not really using a battery and would like to make a 10.5 volt/30 amp supply to ensure I have room to expand in the future. I've look at several schematics of DC-DC converters using a buck/boost converter. Would this be a good way to go or should I look at a different avenue?
Thanks in advance.
[Edit: Fixed link]
Sun Sept 22 2013, 03:24AM
What is the supply source for your desired SMPS? 120Vac ?
(when you say your not using a battery, but then mention a DC-DC topology it confuses me), and your link doesnt seem to work...
Pinky's Brain
Sun Sept 22 2013, 03:51AM
Buck/boost isn't isolated, that shouldn't be an option.
A transformer based switching converter which goes from rectified line voltage to 10.5 Volt would certainly be smallest, but it's not a trivial design.
People have modded server power supplies (which are switching converters) to get high current 12V supplies, which you could drop to 10.5 with a linear regulator.
U4R1A
Sun Sept 22 2013, 03:56AM
Yup. I would like to use mains and the dc to dc part comes from the rectifying of mains voltage. If you copy the link into your address bar it works. Since I'm using mains and I only need ~10.5 volts I guess I only need a buck converter. Unless there is an advantage of using a boost/buck.
Edit*** I made this post before I saw your post. I need this power supply to be as efficient as possible. When this project is done the mains voltage will be replace with ~170 volt battery supply.
Pinky's Brain
Sun Sept 22 2013, 04:14AM
If it's going to run off a high voltage battery in the end you could use an isolated transformer in the mean time, this allows you to ground one of the inputs for your buck converter so you can be sure you aren't putting mains voltage into your robot (relative to ground, not necessarily a problem for the robot's circuitry ... but it might be a problem for you if you go poking in it expecting only 12 Volt).
At these kind of huge ratios normal buck converters aren't terribly efficient though.
Sun Sept 22 2013, 09:43AM
I would probably go for PC power supplies, the most watts/cost AND isolated.
They all convert ac to dc for the output switcher
so if you start with a 120 Vac input smpsu
later you can just connect your 170 Vdc battery to the dc bus.
This is of course true of all modern cheap smpsu.
Better smpsu have a pfc front end which may not be so easy to bypass
so non-pfc smpsu is what you're looking for.
I would find difficulty buying the parts for the cost of a PC smpsu,
Almost all smpsu can be easily modified for lower output voltage (usually just one resistor)
so save time, cost, frustration and legal liabilities
use ready made smpsu, even if you need 2, 3, 4 units as opposed to one large one,
... call it a redundancy feature / expandability function!
doctor electrons
Sun Sept 22 2013, 01:02PM
Check out MeanWell Power supplies, they're as cheap as it gets and should work for you.
I have a 12vdc 30amp meanwell running some tec modules and its been bulletproof for
over a year now.
