  • Guests: 36
Sulaiman (71)
teslarevolution (29)
AromaZ (69)
12/04 Sulaiman (71)
12/04 teslarevolution (29)
12/04 AromaZ (69)
Any good software fom simolation of transients ?
Newton Brawn
Wed Aug 28 2013, 06:11PM Print
Newton Brawn Registered Member #3343 Joined: Thu Oct 21 2010, 04:06PM
Hi All !
1377712979 3343 FT0 Ignitor Jpg
I am working in the above circuit for ignition of sodium/ mercuty vapour light bulbs. The circuit above works well, BUT need see the waveforms, peak voltages and currents, pulse duration, etc
I am thinking to use a software for circuit simulation. I do not know any soft for that .
The soft as to be: computer resident ( not web or on line placed), operate with windows XP,
Hability to solve circuits with 7-15 components, as the abocve circuit,
Simulates diodes, SCR, TRIACS, Sidacs, Diacs, transformers.
... and easy to read instructions.
If it is free it will be very nice
thanks
Newton
Ps I have used before EDSA, ETAP, for power circuit analyses.
Mattski
Wed Aug 28 2013, 06:49PM
LTSpice probably meets your needs. It's free, it can do transient simulation which is probably what you need. Link2
Some of the components you want to simulate (Diode, SCR, Triac, Sidac, Diac) you'll need models for. Diodes you can generally get models from the vendor or by googling around, or you can use a simple idealized model depending on accuracy that you need. For the other components I don't know if they are built in to LTSpice but you can probably find some models on the Yahoo group: Link2
Andy
Wed Aug 28 2013, 07:11PM
Hi Newton Brawn
I use Link2, its free for 30days, and is easy to learn to use
Wed Aug 28 2013, 07:39PM
I would go with LTspice or Qucs, both of them have plenty of tutorials that can help you out simulating a simple circuit like that
Dr. Slack
Wed Aug 28 2013, 09:28PM
LTSpice is basically good, but its GUI is so ar$e-about-face that it takes a real effort of will to drive. However, I'm forcing myself to convert to it from the so-much-smoother Simetrix, because the latter's free version is limited to 150 nodes, so one op-amp will simulate but two generally won't. For your number of components, that may not be an issue.
2Spoons
Wed Aug 28 2013, 10:55PM
+1 to Simetrix. I've used LTspice too, and the interface needs some serious help. For what you are doing Simetrix Demo will be fine.
Mattski
Thu Aug 29 2013, 02:50AM
Yeah, LTSpice does have a nonstandard UI, but once I learned the interface which didn't take too long I found it very efficient and quick to use. I still use it from time to time when I just want to do a simple simulation, it's hard to beat it for efficiency.
Something like Simetrix, or the free version or OrCAD will be more powerful, but you have limitations on the free version. And personally I found OrCAD somewhat complex, not good for just running a quick simulation.
Thu Aug 29 2013, 05:08AM
AFAIK the load/lamp/arc is not modeled in the software so none of the above will give a 'correct' simulation unless you can model the lamp load.
Newton Brawn
Fri Aug 30 2013, 12:49AM
Sulaiman:
Thanks for you advice. The real purpose is produce sparks in a 1-2mm gap, The lamp will be not used here.
Load is free air spark
How to model the spark in a 1-2 mm air gap?
What software ?
Thanks
Newton Brawn
Fri Aug 30 2013, 01:04AM
Mattsky,
Yes, I just want to do a simple simulation.
Thanks, I will see the LTspice and Yahoo group .
