  • Guests: 66
Oil burner SGTC
Platinum
Thu Aug 22 2013, 03:53PM Print
I need help in building my third Tesla coil, my last two didn't last long because I didn't have any materiel to work with this time I'd like to build a SGTC with my 8kv(12k amplified?) 20ma oil burner transformer.
This is the specs of the coil
Currently what I have so far is:
Plenty of 6mm diameter copper brake pipe
Table to hold coil and components
Alot of clear polycarbonate
Spark gap with adjustable tungsten electrodes (thanks work!)
ALOT of spade connectors if they are of use
So I just need to make the MMC (I need a bit of help with that.)
