  • Guests: 75
Ian (37)
Lucas (40)
01/31 Mathias (42)
01/31 slash128v6 (53)
02/01 Barry (71)
Vacuum Pumps - I need an education
Tue Aug 27 2013, 04:03PM
so when pulling a vacuum for oil filling purposes, do I pull the vacuum while the transformer is under oil? then let the oil follow the leaving air? then hold it for a few minutes for good measure?
Tue Aug 27 2013, 05:27PM
Patrick wrote ...
Yes, wait until the bubbles stop, then let it up to ambient pressure, and the oil will fill the voids. You'll be surprised just how much oil will be sucked in, you need quite a bit.
EDIT: Some systems pull the vacuum first, and then cover the xformer in oil, and then let it up to ambient. These systems are supposed to be better.
Tue Aug 27 2013, 06:33PM
Ash Small wrote ...
Yup, for example high voltage utility transformers and x-ray transformers. The rectangular steel tanks of pad-mounted utility transformers are designed to withstand full vacuum inside.
Suppose we want to hold the vacuum for a while at a modest 0.2 torr, to extract not only air but absorbed moisture in insulation materials. Any bubbles would expand by a factor of 15 in diameter and 3800 in buoyancy.
Well, with an absolute pressure of zero (perfect vacuum) over the oil, we would hit 0.2 torr at a depth of 3 mm below the oil surface.
Under 6 inches of oil the pressure can never be less than 10 torr (1/76 atmosphere), at least in Earth gravity.
Carl Pugh told me that where he worked, they would admit dielectric oil to an evacuated tank through a fine spray nozzle at the top. A handy opportunity for final drying and degassing of the oil. I figure that since it's already in a vacuum, the oil mist would promptly settle rather than be sucked into vacuum pump.
Ash: Thank you for the report of a successful commercial process where the oil goes in first. I think there are many applications where that simpler approach is good enough.
Tue Aug 27 2013, 11:32PM
klugesmith wrote ...
that's an excellent point, never would have thought of this!!!
Wed Aug 28 2013, 10:52AM
Actually the process I described used a 'varnish' (possibly polyurethane?) which was heated to ~100 C?, then the Xformers were vacuum impregnated, then the Xformers were baked @ 150-200 C? for eight hours, possibly to soften the varnish so it became less viscous, I don't know?
It was that varnish that never seems to fully cure.
I'd certainly boil the oil and put it under vacuum first.
