  • Guests: 38
Sulaiman (71)
teslarevolution (29)
AromaZ (69)
12/04 Sulaiman (71)
12/04 teslarevolution (29)
12/04 AromaZ (69)
Lenard tube.
StormInABottle
Fri Aug 02 2013, 08:08PM Print
StormInABottle Registered Member #9252 Joined: Fri Jan 04 2013, 06:27AM
I was thinking about making a lenard tube (Electron gun) and that project needs a vacuum pump. So i basically want to ask. Would something like this work?
And would the voltage of a DC flyback work? Also would a AC flyback give better results?
Feathers
Fri Aug 02 2013, 08:24PM
Feathers Registered Member #10052 Joined: Thu Feb 07 2013, 11:31PM
Tubes like this operate between .1 and .005 pascal (.00075-.0000375 torr), which is, concerning measurment in inches of Mercury, basically a perfect vacuum (29.92 inHg below atmospheric).
This is beyond the reach of the tire-inflator pump.
Just watch out, get above 10-20 KV acceleration potential and you'll start making penetrating-wavelength X-rays. This is why color TVs (30-40KV) use thick leaded glass.
StormInABottle
Fri Aug 02 2013, 08:35PM
What about 15 kv? Also would something like that work?
What about trying to extract the CRT from some old color TV?
HDF49
Fri Aug 02 2013, 08:43PM
HDF49 Registered Member #977 Joined: Thu Aug 30 2007, 06:57PM
You need a DC voltage to keep the electron stream in one direction, from the filament/cathode to the anode
StormInABottle
Fri Aug 02 2013, 08:45PM
Okay. DC flyback then. One that i can run at 15 kv.
But what about the vacuum pump video i posted above? And what about trying to extract the CRT?
StormInABottle
Fri Aug 02 2013, 09:05PM
The vacuum pump in the video. The guy says it has a maximum of 30 HG. Which is equal to about 762 mmHG
Which is equal to 101 591.645 pascals. Right?
RateReducer
Sat Aug 03 2013, 02:31PM
RateReducer Registered Member #4603 Joined: Wed Apr 25 2012, 07:33PM
Thats my "electron gun" ^^
I used a cheap vacuum pump - it worked...
StormInABottle
Sat Aug 03 2013, 04:44PM
Great. Can you charge people up with that gun? Make their hair stand and such? Or make something similar to corona or ST Elmo fire? Or make things hot due to the bombardment of electrons? I read on a random website that an electron gun can be used to cut through metal like butter. Is that true?
RateReducer
Sat Aug 03 2013, 06:26PM
It just luminates the powder form the inside of a neon bulb - nothing else ^^
Hmmm strong electron guns are used in PVD systems. Those guns are really powerfull. They vaporise metals.
StormInABottle
Sat Aug 03 2013, 10:52PM
I would give making one of them a shot. But i do not like X-Rays :P. Also can you try to light the electron beam on aluminum foil or copper wire for example? I bet that they would make corona. And. If i point it at a person. Will he get charged up and electrocute everything around him :P. And since when does a fluorescent light or neon bulb have powder o.o. I broke into a few. And it was empty. Aside from the wonderful smell of mercury tho haha
