  • Guests: 74
Ian (37)
Lucas (40)
01/30 Ian (37)
01/30 Lucas (40)
01/31 Mathias (42)
Weird transformer output waveform distortion
Thu Aug 01 2013, 12:07AM Print
Hi all,
When doing some measurements with my scope I sometimes need to display line voltage to compare it with another signal.
So I quickly built a small mains adapter. Basically, it is a switch, a neon bulb with its resistor, a 12V 1VA molded transformer, and an adjustable voltage divider. Resistance across the secondary is around 12k and a potentiometer allows me to vary output voltage from 0 to 5V.
Post0110
Post0111
After putting everything in place and connecting the adapter to the scope I was unpleasantly surprised to see a heavily distorded waveform.
I first though it could come form something wrong in my setup, but when I directly scoped the output of the transformer I got the same problem.
Post0112
I have two of these small transformers so I checked the 2nd one alone, and I got a nice sinus
Post0113
Post0114
Then I thought this could be due to the fact my transformer is glued in the aluminium enclosure, so I put my other transformer in the same kind of enclosure, and I still got a nice signal
Post0115
Any idea on what can cause this problem on my setup and/or how to fix it would be much appreciated :)
Thanks
Thu Aug 01 2013, 02:47AM
Did you also check the first one alone without LED etc?
Your distorted signal looks like your seeing the odd harmonics if that is any help to you.
Thu Aug 01 2013, 09:39AM
This is the waveform I'd expect from a cheap transformer that is saturating. There can also be a phase shift due to the RL time constant of the primary winding.
A small toroidal transformer would give a better result.
Thu Aug 01 2013, 11:46PM
Hi,
@Mads: Yes I also checked the first transformer without anything else than the probe connected to the secondary and I got the same distorded waveform.
The light is not a LED but a neon bulb connected on the primary side, Could this neon bulb cause this problem ?
@Steve: Can the transformer saturate with barely no load ? It is rated 1W and I'm actually "pumping" ~0,012W
It is indeed a cheap transformer, I got them for 3.80€ each
I was first planning to use a toroidal transformer, but I couldn't find such a small one. My enclosure inner width is 35mm and I'd like to keep this adapter as small as possible.
Well I might try with the 2nd one as it seems to give a decent output, unless I can find a small enough toroidal transformer
Thanks guys for your replies
Dr. Slack
Fri Aug 02 2013, 06:23AM
A transformer saturates with too much input voltage, this effect is worst at no load. As the output current rises, so does the input current and the primary IR voltage drop, which reduces the input voltage the core sees, and so improves saturation.
If you have a variac, first check its output waveform. Then use it to power your suspect transformer. Wind the volts up and down around nominal and check the output waveform.
Fabio
Fri Aug 02 2013, 09:27AM
Fabio Registered Member #122 Joined: Fri Feb 10 2006, 12:55PM
A power transformer is different from a potential transformer; they are the same apparatus but the first one works closer to the highest magnetic flux that the core can handle in order to lowering the dimension per watt (and cost per watt) and the second one works with lower magnetic flux in order to improve the stability and to reduce the distorsions of the waveform.
Try to buy a similar transformer with 400V input, it might help.
EDIT:
You can also try to use two identical transformers (with the primary windings in series and the secondary windings in parallel), every transformer will be energized with only half of his nominal voltage and the magnetic flux will be less.
Ciao!
Fabio.
Fri Aug 02 2013, 10:47AM
Fabio, I have seen two 230V transformers in series used for a line sync circuit in a commercial apparatus for that exact reason. smile
I've also had some luck running these small cheap transformers in "zero field" mode when I wanted a really accurate line voltage reference with low distortion and phase shift. I was able to get good performance from 16 to 400Hz using more or less the circuit shown here: Link2
I was proud of this piece of engineering, as it made the performance much better while decreasing the cost and getting rid of one of the transformers. But unfortunately it never made it into the final product. Once we realised bringing line voltage into the box would require a lot of expensive testing to the CE Low Voltage Directive, we left out the line sync circuit altogether frown
Fri Aug 02 2013, 04:56PM
Thanks guys for these clear answers
I'm somehow at ease to see it's a common problem taken into account in commercial setups. I will try these suggestions and let you know how it goes
Just one point:
Dr. Slack wrote ...
How can I do this without an insulation transformer ? I can't connect my scope's ground to mains neutral
Dr. Slack
Fri Aug 02 2013, 09:50PM
PhilGood wrote ...
There are several ways to do this, with different pros and cons
a) If you have a dual channel scope, with a channel 2 invert and add facility, then you can use the two probes as a differential input
b) If you promise not to electrocute yourself, then disconnecting the scope ground breaks any ground loop current
c) You could build a simple 'ground breaker', based on a simple differential amplifier, powered from a battery
d) Put a couple of transformers in series/parallel as suggested by Fabio and endorsed by Steve to make a reasonably linear isolation transformer
Fri Aug 02 2013, 10:15PM
Dr. Slack wrote ...
Oh true, I forgot I can do that, thanks smile
