  • Guests: 35
Quick question about homemade caps
Chip Fixes
Mon Jul 29 2013, 10:34PM Print
I bought 12 glass Snapple bottles and mixed 3 cups of iodized salt in 1 gallon of water. I have filled up each Snapple bottle with 1.75 cups of salt water and then filled the rest up with vegtable oil. Link2
I checked the capacitance with my dmm and it's showing 0.90nF which seems low to me. Do I need to charge the caps before I read the capacitance, and if so, how should I go about doing that?
Finally, my coil is 3.5" in diameter, and 20" tall wound with 26awg wire. How much capacitance do I need for a spark gap tesla coil? I'm using a 15kv 30ma NST. Also, how wide should my NST safety gap be?
Thanks a bunch!
Mon Jul 29 2013, 10:55PM
The question begging to be asked is why are you using bottle capacitors to begin with in this day of age?
With a 15kV/30mA NST, you should be able to get the proper capacitance with a few MMC capacitors at probably not much more than what it would cost for 12 bottles of Snapple.
To calculate the capacitance you need, download WinTelsa or TeslaCad 2.0 or JavaTC. These are nice calculators which will calculate the amount of capacitance you need.
Chip Fixes
Mon Jul 29 2013, 11:52PM
Uh I didn't want to wait for shipping and this way it's not a big deal if they explode because they were only a dollar each.
Here's the stuff from JavaTC: Link2
I'm not sure what I'm doing for the primary coil yet, should I just make something up?
Thanks
EDIT: Plus, Snapple capacitors look sweet!
Chip Fixes
Tue Jul 30 2013, 03:52AM
Alright now I understand that the primary coil really depends on the tank capacitor. Unfortunately, I don't know much about the specs of snapple capacitors. I was thinking two lines of 6 caps in parralel and then put both lines in series with each other, that should give me at least a few nF, hopefully without any exploding glass. Then cobble together a primary helicoil of maybe 10 turns with a 4" radius and see what happens?
EDIT: Found the autotune box... Guess I'm looking at about 35 turns on a 10" dia primary helicoil
