  • Guests: 47
Sulaiman (71)
teslarevolution (29)
AromaZ (69)
12/04 Sulaiman (71)
12/04 teslarevolution (29)
12/04 AromaZ (69)
Epstein Frame questions
Tony Matt
Mon Jul 22 2013, 02:47AM Print
Tony Matt Registered Member #3700 Joined: Sat Feb 19 2011, 12:59PM
Hi All !
Iam triyng to get information regardig the Epstein test in order to trace the B X H curves from a electrical steel. Also interested to trace the curve for exitation VA X B of E tranformer core. Calculation procedures.
Please, any information is very wellcome
Thanks
Newton Brawn
Sat Jul 27 2013, 11:40PM
Newton Brawn Registered Member #3343 Joined: Thu Oct 21 2010, 04:06PM
Hi Tony!
Here some info :
The Si electrical steel is cutted in 30 x 300 mm plates and assembled in the coils as a transformer core.
Primary coil = 700 turns, secondary 700 turns also
The plates over lap each other at the 4 corners such way that the magnetic mean circuit lenght is 94cm, and the core cross section is 15 x 30mm = 0.00045m2.
The ac voltage is applyed step by step in the primary coil. At same time the primary current and voltage at the SECONDARY is recorded.
From the secondary voltage the induction in the core is calculated as Bmax = Erms/(4.44xNxFxA)
N is the number of turns, 700
F = line frequency , may be 60Hz
A = core cross section, 0.00045m2
B= induction, tesla
From the primary coil current the amper turn per meter in the core is calculated.
H= Irms x700/0.94
The Hpeak is calculed as 1.41xIrmsx700/0.94
Then the BxH curve is traced folowing the values of Bmax and amper turn/m
Using a spreadsheet , the Bmax X H is ploted
Exitation apparent power VA/kg:
The Si steel specfic gravity ia about 7.7, so the weight of magnetic circuit may be calculated and the VA/kg calculated as secondary voltage x primary current / weight and ploted.
i hope this help.
