  • Guests: 65
01/12 RoV IW3IPD (63)
Joule thief CFL
Mon Jul 15 2013, 08:49PM Print
A side note, you can get some very nice dust toroiden from broken flat screen TVs.
I saved ten (!) from a single 32" heading for the WEEE bin.
Also handy, save the wire from an old digital clock for the primaries.
Obtain a small DC motor and wind yourself some Litz wire, this increases efficiency many percent.
-A
Dri0m
Tue Jul 16 2013, 04:04PM
Dri0m Registered Member #4497 Joined: Thu Apr 19 2012, 12:53PM
I tried this so many times, different transistors, coils, voltage, everything, and never got it worked. Then i bought 10W 12V CFL for 0.5$ and boom, JT can go to hell :D
Tue Jul 16 2013, 04:54PM
Neat! I didn't realise 12V CFLs were available. Would make a great cheap portable work light.
Wed Jul 17 2013, 08:49PM
Re. not working. Did you check that your 2N3055's actually worked?
Also its really easy to mess up the transformer phasing, done this before.
I've had some success building a test jig for transistors, if they work in this then they should be fine for a JT, it has to do with the gain at high frequency.
To make a sub optimal transistor work, try using more turns on the feedback winding and also add a series resistor; sometimes this will drop the transistor out of hard saturation and allow the circuit to start up.
