  • Guests: 34
midi sstc driver board questions
teslarevolution
Wed Jul 10 2013, 03:01AM Print
teslarevolution Registered Member #16903 Joined: Thu May 09 2013, 08:00PM
Okay I am building a midi interrupted sstc and decided to etch my own board i've just finished the board layout and want your opinion/improvements on it
thanks
1373425259 16903 FT0 Driver Board
teravolt
Wed Jul 10 2013, 03:50AM
I found this error. it may be helpful if you have a schematic
1373428202 195 FT155708 Errror
Wed Jul 10 2013, 01:35PM
1. There are no bypass capacitors on any of the ICs. A 0.1uF should be provided directly across the VCC / GND of each IC.
2. For power coming onto the board, there should be a bulk storage capacitor for power. This is generally sized about 10x the total bypass capacitance you have on the board. (General guideline)
teslarevolution
Wed Jul 10 2013, 04:52PM
The schmatic is steve wards mini sstc but with the 555 interrupter replaced by a polyphonic pic interrputer
teslarevolution
Fri Jul 12 2013, 07:20PM
okay i've updated the board by putting bypass caps but the power will filtered on another board. also i changed the 74hc14 dip to a SN74HCT14DRG3 soic because that's all i could get ahold of.
1373656643 16903 FT155708 Driver Board Upadate
schematic
1373656778 16903 FT155708 Stevewardsstc
teslarevolution
Sun Jul 14 2013, 05:45PM
And here is the dc power supply board
1373823919 16903 FT155708 Power Board
Sun Jul 14 2013, 07:08PM
You still want to have a small reservoir capacitor on your target board.
A 100uF-1000uF would probably be good.
Its good practice, especially if there are long wires between the two boards.
