quick question about VTTC res frequency
Patric
Sun Jul 07 2013, 06:55PM
Registered Member #2899
Is it possible that my primary works (and it works, but not very famous) at the double resonance frequency of the secondary resonance frequency? (first harmonic)
Sigurthr
Registered Member #4463
You would get a voltage maxima node at the center of the secondary. I did this once by accident and it nearly destroyed a secondary since there was breakout in the center and none at the top load.
Patric
Thank you!
