  • Guests: 40
what awg of wire to wind secondary
teslarevolution
Tue Jul 02 2013, 09:12PM Print
teslarevolution Registered Member #16903 Joined: Thu May 09 2013, 08:00PM
okay I have a 18 inch Lon 4 inch diameter pipe that I want to wind for my secondary coil for my Tesla coil but I don't know if I should use 26 or 24 AWG wire to wind it with so which one is better for winding by hand
Tue Jul 02 2013, 11:46PM
If it's for a spark gap TC I'd go with the 26 AWG
mainly because this will result in a larger primary inductance/impedance
(all other things being equal)
which gives less wear on the spark gap due to lower operating current.
teslarevolution
Tue Jul 02 2013, 11:55PM
no its going to be a solid state Tesla coil So would I go with a lower gauge wire
Feathers
Wed Jul 03 2013, 04:36AM
Feathers Registered Member #10052 Joined: Thu Feb 07 2013, 11:31PM
In either case, I would go with 26 gauge.
This will lower the secondary Fres, so you can use a higher Z tank circuit.
A coil that size will run better with lower peak currents and longer on times.
Don't hand-wind! Drill holes in a couple of 2X4 stubs, clamp them to the table, run a dowel through the coilform. Use a rubber band as a belt between the coilform and the end of a drill.
Wind and laquer on one jig in one go!
It will save you a lot of time and trouble.
Wed Jul 03 2013, 02:04PM
Download WinTesla or JavaTC. Determine what frequency you need for your coil and go from there.
For DRSSTCs, you generally want to aim for about 50-100kHz (with Toroid) for the CM300/CM600 based coils, and perhaps up to 250-300kHz if using smaller IGBTs.
DRSSTCs generally 30-32 AWG.
With spark gap coils, you can make larger coils and probably get away with 22-30 AWG - again depending on frequency you want. Download a calculator to determine what resonant frequency you require for your design.
My paper here: How I Build mY tesla Coils is a good introduction into how to use calculators to determine coil specs, etc...
teslarevolution
Wed Jul 03 2013, 04:47PM
OK thanks that helped a lot
