  • Guests: 63
Mathias (42)
slash128v6 (53)
01/31 Mathias (42)
01/31 slash128v6 (53)
02/01 Barry (71)
Skin effect and khz driven electric motors.
Fri Jul 05 2013, 02:25PM
Well, proper design means optimising the overall design of the system. Reducing the current ripple means increasing the PWM switching frequency, hence suffering more switching losses in the inverter. If the increased switching losses outweigh the reduced losses in the motor, then it's not an optimal system.
Skin effect losses from actual torque-producing harmonics in a motor with a non-sinusoidal back EMF are another story, possibly a lot more interesting.
Fri Jul 05 2013, 03:08PM
Well with usual DC motors the "negligible ripple frequency" is below 20 kHz, and for modern MOSFETs and Schottky diodes, 100 kHz is no problem. Of course there can be some kinds of motors which need higher switching frequency, or use a H-bridge with unipolar drive which doubles the frequency on the motor.
Fri Jul 05 2013, 04:01PM
Steve Conner wrote ...
yes, and the more i learn, and experience, the cheap 9 to 12 USD chinese ESC's are clearly less well designed than the 70-80 US$ Castle ESC's, which actively watch the analog waveform across the phases.
