  • Guests: 29
12/06 Dago (37)
12/06 Z28Fistergod (39)
12/06 JonIverson (45)
Expanded scale voltmeter
Billybobjoe
Tue Jul 02 2013, 02:11AM Print
Hi there,
I picked up an expanded scale 120VAC meter made by Simpson, probably circa 1960. Unfortunately I can only get it to deflect when I apply >120V, even though it measures from 100-130V.
Has anyone ever seen one of these before? It looks like it was hand assembled and its very difficult to see whats going on in it because of the cramped wiring.
How does it work? I'm having trouble diagramming it because of the layout. Is there something special about the yellow resistors? One of them is labelled 1400Ω but is shorted through its center and a small black disc at one end measures 62Ω across it. See pics. More questions to follow, but I may be able to answer them myself with a little more insight into this thing.
1372731088 396 FT0 Img 0928
1372731088 396 FT0 Img 0929
1372731088 396 FT0 Img 0926
johnf
Tue Jul 02 2013, 03:24AM
The black disc is probably a varistor of value 100 volts.
you can approximate these with a new varistor or a bidirectional 90volt protection diode
it has to be bidirectional to make the moving iron meter work
Billybobjoe
Wed Jul 03 2013, 03:15PM
johnf wrote ...
Thank you. After some testing it does seem to be a 4.4v varistor. The low value is because the unit contains a step down transformer so all circuitry after that is at low potential.
