  • Guests: 42
01/18 Noelle (43)
01/18 King_of_Junk (36)
01/18 Ixz (35)
Primary coil question
Apparition
Sun Jun 30 2013, 12:14PM Print
Apparition Registered Member #15020 Joined: Thu Apr 25 2013, 04:25AM
I am looking at using some 5mm copper tubing for my primary and was wondering if was ok to use 2 lengths of 15 meters piping as it works out to be $30 vs $95 for a 25 meter length.
Cheers in advance for any advice
Jason
Sun Jun 30 2013, 12:20PM
Assuming that you have the ability to solder/clamp/join the two pieces together, the only 'downside' is cosmetics.
How many Watts will you be using? .. 5mm o.d. may overheat above a few hundred watts.
Apparition
Sun Jun 30 2013, 12:50PM
I am using a 12kv, 30ma NST the longest it will run would be 30 to 60 seconds.
I was thinking about using an insert and soldering them together and placing a small bit of heat shrink over it or a little bit of copper paint to try and make it look better.
Sun Jun 30 2013, 07:33PM
Absolutely. The easiest way to do this is take a piece of wire that fits inside the tube, or similar, and use to splice the two copper tubes together and then solder together.
Apparition
Mon Jul 01 2013, 10:26AM
Thanks for everyone help, always good to hear that I will save some money which is hard in this hobby.
Mon Jul 01 2013, 12:04PM
Apparition wrote ...
Jason
I'm just curious why 30 meters of piping cost only $30.00 vs $95.00 for a 25 meter length?
Copper is generally sold by the weight.
Apparition
Mon Jul 01 2013, 01:46PM
The stores I tried said they could get 15 meters lengths easy but 25 meters are hard to find and they are charged a lot more. Seems like b/s to me but i am happy to get 2 lengths
