  • Guests: 30
genious 7 (32)
07/12 genious 7 (32)
07/13 Friday (55)
07/13 robismor (30)
Stockbridge dampers on powerlines.
Thu Jun 27 2013, 02:57PM Print
do those "dogbone" oscillation dampers we all see on power lines have to be near the point of suspension? or can they be elsewhere on the curve of the line? I don't know if im seeing a connection or repair junction or a oscillation control device on this one funny wire...
Ash Small
Thu Jun 27 2013, 03:56PM
Patrick wrote ...
Can you post a photo, Patrick?
Thu Jun 27 2013, 06:14PM
They are generally placed near the connection points on the line as those areas are most sensitive. Typically one on either side. However, if the line is especially long, you may see more than one one set per span.
Also, they are MUCH bigger than they look. Up in the air they appear rather small, but when you see them in person they are HUGE and quite heavy.
Fri Jun 28 2013, 01:54AM
Ash Small wrote ...
Patrick wrote ...
ok ill get pics, it looks like a tennis racket, though I think its always half way up the wooden poles, on the (lower voltage telecommunications, I think) cable.
Fri Jun 28 2013, 01:06PM
Those tennis racket things you see are actually sensors that are used to measure magnetic field and thus the impedance of the grid in a sense.
Fri Jun 28 2013, 03:49PM
EasternVoltageResearch wrote ...
im presuming they need high mass and large physical dimensions to attenuate the lower physical frequencies, 0.3 Hz gallops' might be hard to impede any other way.
so they are part of the power lines not communication lines?
Sun Jun 30 2013, 07:35PM
I'm not sure how exactly they are wired. Some I see at the base of the high power lines (no communication lines on poles), and others seem to be on the lower communication lines.
