  • Guests: 68
12/04 Sulaiman (71)
12/04 teslarevolution (29)
12/04 AromaZ (69)
Y1 capacitors
kimbomba
Mon Jun 24 2013, 01:28AM Print
kimbomba Registered Member #3854 Joined: Fri Apr 29 2011, 03:45AM
Are Y1 caps suitable for a marx generator?
Mon Jun 24 2013, 08:29AM
I made a small 6 staged Marx generator from these kind of capacitors, supply was 4kVDC. Worked fine.
For higher voltages / power levels I would properly use the same type capacitors that we normally see in DRSSTC MMCs. (metallized foil film, MKP etc)
Mon Jun 24 2013, 09:58AM
For a marx just use the cheapest capacitors you can find, usually the blue ceramic ones. There is a large sortiment of them on Ebay, up to 30 kV (oil may be required) with capacitances in the nanofarad range.
Mon Jun 24 2013, 04:33PM
I wonder how a capacitor with a DC rating of 8kV can have an AC rating of only 250V
Mon Jun 24 2013, 05:41PM
That may be the test voltage and working voltage.
Mon Jun 24 2013, 06:07PM
There can be a huge difference due to dielectric and technology used, if you look at the hydraulic analogy here: Link2 and hold it up against information from here Link2 and here Link2 you should have a good idea about the difference in ratings.
Googled "capacitors ac dc rating explained"
Mon Jun 24 2013, 06:43PM
The safety Y.. capacitors are tested for much higher voltage than is the actual line voltage. From the law, they are required to withstand a 2 kV AC voltage applied between the live/neutral and protective earth, which is where these capacitors go.
