  • Guests: 56
Sulaiman (71)
teslarevolution (29)
AromaZ (69)
12/04 Sulaiman (71)
12/04 teslarevolution (29)
12/04 AromaZ (69)
What is the cheapest transformer that can is better that a mot
MR-ZAPPY
Sun Jul 21 2013, 10:30PM
MR-ZAPPY Registered Member #16018 Joined: Fri May 03 2013, 07:19PM
I got a 1600 watt mot a few weeks ago. Even though is is a single mot it has arcs around 6 inches without resonant caps and a ballast
radiotech
Mon Jul 22 2013, 07:35AM
There are types of transformers, like pole transformers, that are intended to drop voltages
from distribution levels, 2200, 6600, 13800, to 120/240 etc. for lighting and other loads.
They are dry, and are mounted in cabinets, that also house secondary circuit breakers
and the primary switch. The KVA rating depends on how close the loads are to the panel
cabinet. The idea is, inside a factory, or a high rise building, the power risers are high voltage
to save weight.
If you know what you are looking for, in a scrap yard dealing with old electrical apparatus,
you might be able to buy one for the scrap copper value. Bear in mind, varnished transformer
wire is a real chore to recover for a scrap dealer, and with new environmental laws springing
up concerning organics, they might cut you a deal.
They are heavy, and because dry, easily damaged.
Most are three phase. Beware of entering an abandoned site, thinking that everything is dead.
