  • Guests: 29
  • Most ever online: 441
    Guests: 441, Members: 0 on 01 Oct : 16:32
Michael W. (36)
10/04 Michael W. (36)
10/05 GhostlyFigures (36)
10/06 Ivan Kalafatic (17)
Spark gap Tesla coil not working...
the mad scientist
Wed Jun 19 2013, 01:37PM Print
the mad scientist Registered Member #3768 Joined: Tue Mar 22 2011, 12:46AM
Hello, I am very frustrated at the moment. My spark gap Tesla coil is not producing any sparks from the secondary. I am using a 15kV NST, a rotary spark gap, and a 9.3nF capacitor bank, with this secondary: Link2 it says it should resonate at 9.3nF at 9 or 10 turns... . It makes loud bang sparks from the rotary spark gap, so I can assume the capacitor bank is charging. I will post pictures later when I come back home. I am assuming it has something to do with the primary and secondary positioning or something. I am really frustrated by this, considering all the time and effort I have put into this. It is quite saddening and disheartening actually when it doesn't work...
EDIT:
Pictures: Link2
Also I'm using a counterpoise ground which is just the bottom of the secondary and the strike ring connected to this 4'x3' chicken wire sheet.
Wed Jun 19 2013, 03:07PM
What kind of spark gap are you using? SRSG or ARSG?
You might have too much gap distance in your spark gap. For example, the break-down is not ocurring until the capacitors are way overcharged which is why you are hearing the loud bangs.
I have had this before, but honestly, its been so long since i've built and operated a spark gap coil that i kind of forget what my particular issue was when i had those loud bangs too.
JoeBonanno
Wed Jun 19 2013, 03:16PM
JoeBonanno Registered Member #14660 Joined: Mon Apr 22 2013, 04:05PM
Need more details! mA of the NST?
resonance Freq?
how you made the Rotary? it's in phase?
9.3nF of tank? seems to be a little low!
the mad scientist
Wed Jun 19 2013, 04:11PM
Here are some photos of the coil: Link2
the mad scientist
Thu Jun 20 2013, 03:36PM
Resonate frequency is approx 211 kHz. mA of NST is 30
Feathers
Fri Jun 21 2013, 09:26AM
Feathers Registered Member #10052 Joined: Thu Feb 07 2013, 11:31PM
Unless you are running a very high breakrate, AC coils should run SRSGs (synchronous rotary spark gaps)
You may be using this type of gap, I can't tell.
Richie's site provides the best explanation Link2
I try to explain the way it works in my own coil in this video Link2
For now I would shut off the motor (turn your rotary gap into a static gap with two gaps), and tighten up the gaps to around 1/8" each. It should be easier to troubleshoot from there.
the mad scientist
Fri Jun 21 2013, 06:30PM
HighVoltageFeathers wrote ...
Alright I will try using it as a static gap for now, but is the spacing of the secondary from the primary alright?
