  • Guests: 22
10/09 sbs_2010 (34)
10/09 SoundDoc (50)
10/10 Ryan Parle (44)
Mega big Russian single transistor tesla coil
zilipoper
Mon Jun 17 2013, 08:29PM Print
zilipoper Registered Member #4152 Joined: Thu Oct 20 2011, 10:18PM
hi coilers:)
I present to you indestructible armored tesla coil;DDDDDDDDDDDDD
scheme is so simple that almost no details
in conventional spools of this type are ballast current limiters
here it is not present and the weak transistors without breaker for long duration totally annihilate;D
however, this only works reel interrupter;)
just now
I'm just starting to build this type of coil, and so I want to get 150-300cm streamer
I use a semiconductor FGH60N60SMD
coil while it can operate from 170- 190VAC to do if it breaks above the primary winding
1371500183 4152 FT0  460  972
1371500183 4152 FT0 Dsc 2499
1371500183 4152 FT0 Dsc 2500
1371500239 4152 FT0 Dsc 2501
T0go
1371500239 4152 FT0 Uvfa0r0hzdi
1371500239 4152 FT0 64
1371500239 4152 FT0 2
Mon Jun 17 2013, 10:23PM
You are quite simply amazing when it comes to electronics, all your circuits are original and never really seen before.
I really wish i could get round to building some stuff... just saving up for a func gen and a oscilliscope
Tue Jun 18 2013, 11:59PM
Another original and great design !
You are amazing, Mr Megavolt Wizard wink
Could you please post some pics of the assembly showing components and coils ?
zrg
Wed Jun 19 2013, 02:00PM
zrg Registered Member #4762 Joined: Sun May 06 2012, 05:59PM
Hey, hey, looks like you've forgotten something really important on your schematic smile a huge bunlde of TVSes for example? smile
zilipoper
Fri Jun 21 2013, 09:23PM
hi guys
1371849771 4152 FT155027 5ohsmaqejvw
1371849771 4152 FT155027 Eg2oqejkdju
1371849771 4152 FT155027 Eospnumjnww
1w
1371849818 4152 FT155027 Gvrvfy1wniy
1371849818 4152 FT155027 J2nodjz3ptw
Qqkayhi
1371849818 4152 FT155027 Wabqrb4gvbw
Jazzman56
Wed Jun 26 2013, 12:33PM
Jazzman56 Registered Member #7222 Joined: Sat Oct 13 2012, 06:04AM
Hi, zilipoper
Is there any-chance of getting some of the component values that are not present in the schematic?
Regards,
Jazzman56
zilipoper
Wed Jun 26 2013, 09:21PM
scheme with bugs
after a complete circuit lay
Chip Fixes
Fri Jun 28 2013, 05:47AM
This is amazing, I want to build it tomorrow
zilipoper
Sat Jun 29 2013, 11:04AM
Pulse duration to put at least for the weak transistors
1372503653 4152 FT155027 1111111111111111111
RayeR
Mon Jul 01 2013, 10:46PM
RayeR Registered Member #333 Joined: Mon Mar 20 2006, 06:02PM
Hi dude, your 1st circuit reminds me what I was trying about 10 years ago! Here's my single FET SSTC
http://rayer.g6.cz/teslatr/sstce.htm#FETTC
But in my case I used feedback coil and it didn't work well. I would fear about FET and zeneres by this rude base feed but you made it. Results are really impresive! I think this ISSTC is the best with price&simplicity / power radio that I have ever seen :)
BTW what about MOSFET drain-source voltage spikes? Did you tried to attach scope there? It kick ass your MOSFET hard but it behaves like zener diode and clamping it - this clamped energy is dissipated as heat of course. I can see you run very short bursts. I guess if you will keep run it for a minute at full power it blows off... This can be solved by class E topology (just add some capacitor) but it would require MOSFET for about 4x Vds rating of power supply which is hard to get...
