  • Guests: 37
811A VTTC problems
alf
Sun Jun 16 2013, 05:57AM Print
alf Registered Member #3925 Joined: Fri Jun 03 2011, 10:50AM
Hi,
My 811A VTTC has been needing a new tank capacitor for a while, since the one I first used seems to vary in capacitance when in use.
So a few days ago I tried to use 2 homemade transparency sheet capacitors in series as the tank cap to give around 2.8NF, those capacitors seem to work a lot better and do not vary in capacitance.
However, the sparks are still rather small (<4") and the plates of the tubes glow red-orange at full voltage (240V to the MOT)
One tube runs much hotter than the other, I assume this could be corrected by using a tapped grid coil, although all attempts so far to do so have failed.
I have tried adjusting the topload, primary L, primary C, grid leak resistor (and the capacitor connected across it), grid coil turns, and grid coil position. And none of these things seems to have had much of an effect towards making the sparks any longer and the tubes run cooler.
The filiments are powered in series with a resistor across one to adjust its resistance to that of the other tube's filiment, so that 6.3V is across each.
The schematic ( Link2 ) shows that the bottom of the secondary coil should be at the same potential at the cathodes of the tubes, which is ground potential. I have attempted this, and it seems to increase the size of the sparks, but results in sparks/corona between the secondary coil and the feedback coil.
I am using an earth rod to ground it, which seems to work fine.
The only difference between my coil and the more successful one at Link2 is a rather large difference in the primary former diameter - 4.3" (110mm) instead of 6.3" (160mm) as I live in UK and the closest thing I could find was 110mm pipe, although I probably could have found pipe of the correct diameter if I had looked a bit harder XD
The secondary former is slightly different in size, but not much so... The one specified in the circuit is 2.3" (58mm) and mine is 60mm PVC drainage pipe if I remember correctly.
As far as I can tell, the primary resonance doesn't need to be critical, besides I have tried to change the capacitor and it doesn't seem to help
Should the bottom of the secondary be connected to the cathode of the tubes?
Could this large difference in diameter of the former be the cause of the small sparks and the tubes running too hot?
And in general, any ideas how I can make it work a bit more like its supposed to?
Thanks in advance, Alf
Sun Jun 16 2013, 10:39AM
Hi
1. Did you calculate resonances using JavaTC?
2. Are the tubes new/matched?
3. You need a proper RF capacitor, any homemade one will be lossy in a VTTC.
-Jan
alf
Mon Jun 17 2013, 06:50AM
Dr. Dark Current wrote ...
Hi
-Jan
Thanks for replying...
1-No, I'll do that
2-They are new, and I believe that they are matched aswell
3-Ohh, I will get one and perhaps this is the problem
Thanks again, Alf
Mon Jun 17 2013, 08:28AM
As for the calculations, tune the primary a bit lower than the secondary, and make taps on it. This is an important thing to do.
Then, tubes in parallel sometimes tend to oscillate in push-pull manner on a very high frequency. Few tens of Ohms resistors directly in series with the grids will fix this.
-Jan
alf
Mon Jun 17 2013, 01:07PM
-Jan
Okay, I will remove the plastic insulation from a section of the primary windings, and solder on wires to each turn.
Right, will try this aswell
Thanks again.
Mon Jun 17 2013, 05:42PM
alf wrote ...
I built a 811A coil based on the same schematic, but one tube only Link2
I connected the bottom of secondary to ground (mains earth) and had no problem with this. I dont think such coils really need a separate RF ground because of their low power and because they work in a non-disruptive way.
With the primary and secondary diameters you used, it is weird you are having sparks between secondary and feedback coils when connecting secondary to mains ground. I'd suggest you put your feedback coil under the primary (where secondary's voltage is lower)
As Dr DC said, a decent primary cap is mandatory. Russian K15Y-1 series Link2 are great for this and are easy to fond on ebay.
Could you post some close pics of your whole assembly ? might help
alf
Sun Jun 23 2013, 09:07PM
PhilGood wrote ...
alf wrote ...
Wow. 15CM sparks with one tube
Okay... A decent cap. Will get one soon
Yeah I will take pics and post them when I get a chance.
I simulated the coil with JavaTC as recommended. Sorry it has taken me 5 days to get round to replying somehow
Here are the results: Link2
Thanks for your help..
Alf.
Mon Jun 24 2013, 12:00AM
Hi Alf,
I'm not very familiar with all JavaTC's outputs
One thing I noticed:
'JavaTC' wrote ...
426.21 kHz = Secondary Resonant Frequency
462.56 kHz = Primary Resonant Frequency
Your Primary Resonant Frequency should be at least 10% lower than your Secondary Resonant Frequency
For this you can either add more turns or slightly increase primary C
Then you will use taps to adjust primary coil to the best value
alf
Tue Jun 25 2013, 08:04AM
PhilGood wrote ...
Hi Alf,
'JavaTC' wrote ...
10% lower... Right
I really need to get a proper cap anyway XD
And add taps. Okay will do that
Thanks again.
Alf.
Tue Jun 25 2013, 10:54PM
Hi Alf,
Sorry I just realise 10% might not be enough
You should plan on a primary with a resonant frequency 40% lower than your secondary frequency
Then make taps that allow you to tune your primary from +20% to -40% secondary resonnant frequency
Just change the number of primary turns in JavaTC to find out what is the total number of turns you need, and at which turn you need to start making taps
It's always better to have more taps to play with when tuning your coil, rather then having to build a new primary because you don't have enough turns (this happened to me)
