  • Guests: 39
QCW Modulator
zzz_julian_zzz
Sat Jun 15 2013, 03:09PM Print
Hi Everyone,
I've been trying to build a bus modulator for my first attempt to make QCW DRSSTC.
Unfortunately, i was not able to make it work, and the output waveform of my Class D amplifier is somewhat far from expected which is a linear ramp.. (compared to my signal input).
Just wondering, if anyone could help me with this project, for this are my encounters:
1. I don't know if my ramp signal generator is suitable for this application
2. High Current Draw from AC Mains(variac)
3. Trash output waveforms ( it seems like its just a oscillation wave, even if i inputted a shaped ramp signal)
I've attached (linked) herewith the schematics being used, please help me check if there are mistakes on the circuits. such as isolation issues, feedback and etc,
Any input regarding the subject is highly appreciated,
thank you very much!
1371308951 3964 FT0 Photo0128
1371308953 3964 FT0 Tl3116 Ic
1371308953 3964 FT0 Isolated Gate Drivers
1371308953 3964 FT0 Photo0132
1371308953 3964 FT0 Photo0133
1371308953 3964 FT0 Smps Circuit Isolated Supply
1371308953 3964 FT0 Photo0137
1371308953 3964 FT0 Isolated Gate Driver Pcb
1371308953 3964 FT0 Photo0142
1371308953 3964 FT0 Photo0150
1371308953 3964 FT0 Photo0145
Sat Jun 15 2013, 05:34PM
Hi, do you have any scope shots input vs. output?
I think the problem could be interference from the coil, as op amps are "sensitive" devices and electric field near a TC is strong.
zzz_julian_zzz
Sun Jun 16 2013, 12:22AM
Hi Dr. Current,
Here is my scoped input(yellow) and the ouput of the comparator(TL3116- green)
By the way. in my schematic, the TL3116 IC is supplied on its PIN 1, and 5&6 PINS are connected to ground.
(mistake in my drawing)
Thank you.
1371342153 3964 FT154945 Qcw Output Actual
EDIT: I am still not connecting this bus modulator to any coil, and no dummy loads on its output, so no TC interference i think?.. Thanks!
