  • Guests: 49
Tesla-coil based expiriment
first  2 3 4 5
Andy
Sun Jun 16 2013, 07:30AM
The switch closes to the battery is just to stop the simulator from charging the cap to full volts before the o-scope kicks in.
R2 is to stop C1 from draining into the inductor to quick, well atleast thats how I think it works :)
Sun Jun 16 2013, 09:03AM
tarakan2 wrote ...
Can the collapsing magnetic field in the Tesla coil primary drive an auxiliary coil that would do this job?
Take a look at the antenna feedback used in steve wards mini sstc 5 or how grid leak circuits in class c armstrong osciallator VTTCs are used.
Sun Jun 16 2013, 11:04AM
tarakan2 wrote ...
Can electric arcs be effected by magnetism and if they can, is there any way that would allow the breakdown to be very sharp?
Is it possible to employ some (fairly cheap and abundant) vacuum or gas-filled device for a discharger?
Arcs can certainly be affected by magnetism. A few people here have reported spiralling sparks in magnetic fields recently (Andy's thread on Z-pinch and another thread on electrothermal guns).
I'm not sure I fully understand what yopu mean by your second question, but I assume it's possible.
tarakan2
Sun Jun 16 2013, 03:19PM
tarakan2 Registered Member #3859 Joined: Sun May 01 2011, 03:47PM
I am looking for articles on Z pinch and arc control with magnetic fields.
I would be very pleased if you give me links.
Sun Jun 16 2013, 03:34PM
tarakan2 wrote ...
Here is a link to Andy's Z-pinch thread: Link2
And here is a link to Mr Flatox's ETG thread: Link2
tarakan2
Sun Jun 16 2013, 11:57PM
Ash Small wrote ...
tarakan2 wrote ...
http://4hv.org/e107_files/public/1355777604_4266_FT1630_2.png
Why is there a spark in the middle of the plywood board here?
Or what am I not seeing on this photograph?
(I am currently playing with gas discharge lightning arresters so I cannot see real sparks.)
Mon Jun 17 2013, 06:14AM
tarakan2 wrote ...
Ash Small wrote ...
tarakan2 wrote ...
Andy wrote just above the pictures why the sparks are outside of the pipe...
Mon Jun 17 2013, 06:11PM
tarakan2 wrote ...
Tesla Coil is not a resonant device.
Weird statement ever.
As you can see through many threads here, when tuning a Tesla Coil our goal is to set primary and seconsary resonant frequencies to the same value. Resonance is what makes a Tesla Coil work and this is scientifically proven and explained.
Mon Jun 17 2013, 06:14PM
tarakan2 wrote ...
Well
If I tell, I will be banned from this forum. I have some experimental evidence to prove my point.
Read Secrets of Cold War Technology by Gerry Vassilatos.
MODERATOR - I think its probably time to lock the thread. This thread is moving farther and farther away from real science and into the realm of pseudoscience.
Mon Jun 17 2013, 07:52PM
EasternVoltageResearch wrote ...
While I'm not sure if this thread is going anywhere, I'm not sure it's broken the 'conservation of energy' rule yet.
(but then I'm not a mod smile )
first  2 3 4 5
