  • Guests: 37
09/16 Michael Witt (36)
09/16 AleSeg (15)
09/17 Jyardana (41)
Food for thought
Physics Junkie
Sat Jun 08 2013, 06:48AM Print
Physics Junkie Registered Member #7267 Joined: Tue Oct 16 2012, 12:16AM
A wacky question, but here I go:
Hypothetically, you have a Tesla coil that has a resonant frequency somewhere between 400THz and 800THz. Would it emit light?
Ash Small
Sat Jun 08 2013, 10:00AM
Every functioning Tesla coil I've seen emits light smile
Sat Jun 08 2013, 10:38AM
:-D
The length of wire for such a Tesla coil secondary would be around 100 nanometers. Rather use an LED tongue
Physics Junkie
Sat Jun 08 2013, 11:29AM
:-D I know but, I'm thinking in terms of electromagnetic energy and frequency. After all, we build Tesla coils resonant in the RF spectrum which give off RF radiation generously. Would a Tesla coil in the visible light spectrum radiate light similarly? Different light than from the plasma discharge, of course
Sat Jun 08 2013, 12:26PM
This 400THz Tesla coil already exists, it's called a laser. smile
Some pulsed lasers are powerful enough that when the beam is focused down, the electric component of the field is strong enough to ionise air. The result is a tiny sphere of plasma floating at the lens's focal point. No breakout point required!
Lasers capable of doing this tend to be near infrared, but there's no theoretical reason why it wouldn't work with visible light.
Uspring
Sat Jun 08 2013, 01:41PM
Yes, even coherent light, if the bursts are long enough.
That tempts me to ask, if a laser is more like a SGTC or a DRSSTC? But seriously, a TC is somewhat similar to a one atom laser, where a single atom (secondary) is pumped by a high frequency field (primary).
The main difference is, that a laser uses only a single excitation of an atom, while a tank is multiply excited.
Sat Jun 08 2013, 03:55PM
I think a laser is similar to a Tesla coil because it is using a resonant cavity to create an EM field. From a functional point of view, the laser cavity is analogous to the secondary coil, even if it looks nothing like one.
If you did what you had to do to push the SSTC concept to 400THz, you'd have a diode laser. The tiny cavity is integrated on the chip and pumped by a "feedback driver" made of individual semiconductor atoms.
Physics Junkie
Sat Jun 08 2013, 07:45PM
Steve Conner wrote ...
Makes sense. When you say laser, I immediately think 'straight beam of light'. Now, whether or not it's a focused beam doesn't matter, who cares. That depends if you have a lens of some sort or whatever it takes to focus the light. But still, beam. Light is a wave of oscillating electromagnetic fields perpendicular to the direction it’s travelling which is a straight line. I'm still thinking about it in the point of view of EM waves. The field lines don't exist, duh. But how do you know the direction which the light travels constituting it as a laser-like beam?
I sketched up this weird tiki-voodoo-guy-looking diagram of a Tesla coil and the EM lines cheesey. Now I could have drawn this totally inaccurate in regards to the direction of the EM lines, and I probably did. But you get the point and this is how I am thinking:
1370719342 7267 FT154724 Em Field
I think I sort of get what you mean by a laser (beam) vs. a big haze of red awesomeness. The way I was thinking the photons radiate off the Tesla coil in all directions, like in my diagram.
When you say
the secondary is the resonant cavity in this case just like you said analogous to the laser cavity. So photons would be generated inside the secondary thus beaming out the top in a straight laser-like beam vs. radiating outside of the "resonant cavity" like how I drew it in the picture? (basically the photons would just be emitted along the axis of symmetry out the top travelling in one direction only, vertical)
Sat Jun 08 2013, 09:10PM
A Tesla coil is physically small compared to the wavelength it operates at, so it doesn't have any directionality. On the other hand, the laser cavity is large compared to the wavelength, so it shows strong directional behaviour. For a "haze of red awesomeness" it might be possible to make a spherical cavity that would lase in all directions, but it would be an engineering nightmare. And in fact the strong directional behaviour of lasers is one of the properties that makes them useful. The spherical laser would be nothing but a coloured light bulb with an annoying speckle. smile
Uspring
Sun Jun 09 2013, 02:38PM
As Steve said, a usual TC is small compared to the wavelength. That makes it a dipole radiator. Link2
Most of the energy goes off perpendicular to its axis, nothing along the axis. Lasers are coupled EM systems like TCs, but you shouldn't carry the analogy too far.
