  • Guests: 60
muller (38)
Dr. Mario (38)
Ben Solon (30)
01/27 muller (38)
01/27 Dr. Mario (38)
01/27 Ben Solon (30)
How to power up this He Ne laser?
hsieh
Fri Jun 07 2013, 09:20AM Print
hsieh Registered Member #1412 Joined: Thu Mar 27 2008, 04:07PM
I got this laser tube,but when I google the part number I didn't find any datasheet.How can I know it's voltage and current rating?
1370596629 1412 FT0 Dsc 01621
1370596629 1412 FT0 Dsc 01631
I borrowed this power supply from my teacher,will this work?
Thanks
1370596629 1412 FT0 Dsc 01641
Fri Jun 07 2013, 11:14AM
Read all of this carefully: Link2
You will probably need a 75K ballast resistor, and be sure to get the polarity correct. The current output of the supply is a little high for a 1mW tube but it might well work anyway.
Uniphase are now "JDSU".
hsieh
Fri Jun 07 2013, 11:33AM
Will this driver work?
Or I need something that has current regulation?
Fri Jun 07 2013, 12:02PM
Looks like it would be worth a try. You can always measure the output current and fiddle with the transformer turns ratio to adjust it.
Wastrel
Fri Jun 07 2013, 12:26PM
Wastrel Registered Member #4095 Joined: Thu Sept 15 2011, 03:19PM
The side that connects to the large electrode is the cathode. If you get it the wrong way round the tube will typically work fine but it will die young.
hsieh
Fri Jun 07 2013, 04:14PM
I powered it up with another 6.5ma laser power supply with 100K resistor. My tube gets hot after several minutes. Is this normal?
Shrad
Fri Jun 07 2013, 09:05PM
a hot tube is normal, a hyper hot tube is not (it should not burn your hand to the point you cannot even touch it)
I have a stabilized melles griot hene which gets pretty hot (at least 70°C) and outputs around 1mW
Wastrel
Sat Jun 08 2013, 10:49AM
If the supply is designed for a higher voltage tube it may be pushing a much higher current. I've used a disposable coil meter to measure actual current before, that went quite well and it turned out to be important as the supply was pushing 15ma into a tube rated for 5. Current between tubes seems to vary a lot less than voltage drop, which I assume depends on the lasing length. Your 1mw tube may need less than 1kv.
hsieh
Sat Jun 08 2013, 12:39PM
Wastrel wrote ...
How can I know the current rating without a datasheet? My tube is about 14.5 cm long?
Sat Jun 08 2013, 03:49PM
Compare with other 1mW tubes, should be about the same.
