  • Guests: 32
raff (48)
09/20 PYLEMET-mk2 (36)
09/21 Bill G (65)
09/21 Overclocked (38)
MOT questions
darthtony
Tue Jun 04 2013, 04:02PM Print
darthtony Registered Member #8464 Joined: Mon Dec 03 2012, 02:24PM
I dissasembled a microwave oven transformer, which i have modified with a low voltage high current secondary. Now, because the E section of the core was composed of different plates wich were difficult to glue together, i welded them. Now when i assemble the E and I segments (with the primary and secondary inside of course) and clamp them together, it works but i think that the primary is cosuming more current and it is running hotter than before.Could this because i welded the core?Also does the polarity and orientation of the coil matter?Becasue depending on the orientation of the coil the standby (open circuit) current of the primary varies between 3-7Amps.
johnf
Tue Jun 04 2013, 07:56PM
Darth
This because of two reasons
1./ the core is small compared to capacity as uwaves use the xformer a near full power so the idle current is high due to too smaller core. Not a problem in the uwave in normal use
2./
Welding the core back together will raise the eddy current loses causing the core to grt hot.
Tue Jun 04 2013, 08:04PM
I think the problem could be if you introduced a little air gap in the core.
The Lightning Stalker
Tue Jun 04 2013, 08:07PM
The Lightning Stalker Registered Member #4230 Joined: Sat Nov 26 2011, 05:50AM
It depends on how and where you welded it. MOTs have welds in them, but they are welded in such a way that eddy currents do not form. Actually they do, but they are minimal. Attach some pictures so we can see what you're talking about.
darthtony
Tue Jun 04 2013, 08:23PM
They are two weld going horizontally(crossing all the plates). I dindt think they would cause any problems, because i saw that there were some welds on the core.
