  • Guests: 66
muller (38)
Dr. Mario (38)
Ben Solon (30)
01/27 muller (38)
01/27 Dr. Mario (38)
01/27 Ben Solon (30)
Unknown transformer VA ratings
Alex M
Mon Jun 03 2013, 07:47PM Print
Hi,
So I have this mains step down transformer that I have no idea what its VA rating it is, since I got it out of some old junk years ago. It puts out around 18vac unloaded and then about 17vac with a 1 amp resistive load (22vdc when rectified and smoothed).
It weights about 850 grams and I would say that the secondary winding looks to be around 26-28 SWG.
Here it is next to a PP3 battery for size comparison.
1370286882 3943 FT0 Dsc 3733
On the internet I have read that 15-20VA per lb is a rule of thumb for E I cored transformers, so that would be roughly 30VA? I put it on a load test the other day and at around 1.2 amps is where it started to warm up a bit, but it seemed to cope with a 1.4amp load just fine (these measurement's were taken with a non-true RMS multimeter on a resistive dummy load).
The only thing printed on the transformer is "P0265TA" and "1527", but couldn't find anything online though.
Does the 30VA figure sound about right for something this size and weight? or am I way off with that estimate, as for some reason I think this thing could probably push a little bit more power before it starts complaining.
Thanks smile
Mon Jun 03 2013, 09:57PM
The simplest method is to
find a similar construction transformer of similar weight so similar VA
Mon Jun 03 2013, 10:44PM
I would guess thats good for about 10-20VA depending on size.
My guess is about 18VAC output at 1.5A.
Tue Jun 04 2013, 04:03AM
Please share any experimental data you get, e.g. temperature rise vs. load.
Some things I have learned along the way:
1. Transformer temperature rise and VA rating depend on the RMS current.
That can be significantly higher in circuits with a rectifier, filter, and DC load,
compared to an AC resistive load with the same load current.
It's because of the crest factor in current waveform that periodically boosts the capacitor voltage.
The VA derating factor depends on the type of rectifier and filter.
Some transformers come with a rectifier rating (not to be confused with rectifier transformers).
Here's a reference to start with: Link2
2. For a given transformer weight, VA ratings will of course depend on acceptable temperature rise and operating duty cycle. Yours looks like it's from a consumer electronics or appliance product, so it's probably intended to be energized continuously, and should never get hot enough to feel or smell like it's about to start a fire.
3. Some transformer applications (e.g. MOT's, certain UPS units) spend most of their "on" time at loads near maximum. They can get more VA per pound by using thicker wire and fewer turns, to reduce copper loss at the expense of higher core loss (which is practically independent of load current). I guess they could be distinguished by having lower primary winding resistance than other transformers of the same size and voltage.
Tue Jun 04 2013, 12:20PM
The 'rule of thumb' that I use for continuous current rating is, Idc = 0.62 x Iac.
e.g. 18Vac 18 VA transformer is rated for 1 A rms, with a bridge rectifier and capacitor, Idc = 620 mA.
For 4HV use you can run the transformer hortter !
Wed Jun 12 2013, 12:48PM
For 230 V mains the power is around 1200/R_pri (for small transformers - tens of VA, the constant is larger - around 2000, for very big transformer in the kVA range, it is smaller, like 1000.)
Shrad
Wed Jun 12 2013, 05:12PM
1527 could be a charted code meaning something like 15VAC 27VA, and keep in mind those transformers are usually a couple volts higher than specs
Experimentonomen
Wed Jun 12 2013, 06:58PM
And that specs are almost always highly overrated. Can sometimes be overspecced as much as twice actual power, as was the case with a 800W rated transformer i have from an amplifier, it turned out to be about 400VA in real life.
teravolt
Wed Jun 12 2013, 07:18PM
it looks to me like about 10w
Wed Jun 12 2013, 08:32PM
Experimentonomen wrote ...
Not always, many of my older transformers are rated e.g.
1100VA 24-0-24vout 170vin
can run happly over 2200VA
and my variac can be run at way over 40A for about 30 mins id say when its rated for 25A
