  • Guests: 29
Sanchez (36)
Knarvel (13)
10/16 Sanchez (36)
10/16 Knarvel (13)
Parabolic Reflector
Sun Jun 02 2013, 03:35PM Print
I want to do a few small experiments that require a parabolic reflector;
- solar energy
- optical communications
- directional microphone
- wi-fi
So my ideal would be a 1m diameter astronomical telescope on a fast alt-azimuth mount
but I'm wondering what I can get for a few GBP ?
Obviously I can't get a cheap parabolic reflector that is suitable for everything,
but does anyone know of cheap 'adaptable' options?
e.g. IKEA, B&Q etc.
My main requirement is that the surface reflects light, it doesn't need to be 'optical' quality.
I've looked at all sorts on eBay, solar oven metalised acrylic looks great,
but I'm looking for a cheapskate option.
BigBad
Sun Jun 02 2013, 05:01PM
FWIW I think that Wifi is probably better done with a Yagi, it's easier to get a fairly compact aerial that way with good gain and it's much less sensitive to wind and so forth.
You can build a parabolic reflector covered with aluminium foil on a hardboard backing that's cut into segments and bent into shape and mounted on a wooden frame pretty easily.
Not sure how well it would work for directional microphones, I think that might require relatively heavy materials to work well.
Ash Small
Sun Jun 02 2013, 05:36PM
Do you have access to any scrap satellite dishes?
Cover one in kitchen foil (or reflective coating of your choice).
Sun Jun 02 2013, 06:55PM
I am sure you have must have looked at the cheap 6" make up/shaving magnifying mirrors you can buy on ebay for a few pounds. It struck me that for optical communications you could make an array of these, rather than having one big dish, and have reduced windage to boot.
Dr. Slack
Mon Jun 03 2013, 07:11AM
1m2 wooden baseboard. Glue on radials cut to the appropriate quadratic curve - wood, corrugated card stuck with hotmelt glue is a wonderful roughing material, expanded polystyrene cut with a hot wire. Interpolate with hardboard or cardboard, and surface to taste - alli foil for electromagnetic, cement render for sound.
I've intended to find out how to do the sums on this one day, but have never brushed up my Bessels. Remove a circular aperture from the side of a reasonably air-tight box. Stick down a sheet of plastic, and pull enough low pressure to get a concave curve of sufficient depth. It won't be parabolic, it won't be spherical, but how close will it be to something that's useful? For small depth, it will approximate both of those very well. Capture the surface with glass fibre, or papier mache. Of course, if you do that with an aluminised plastic film, you've got a controllable focal length mirror. If you google 'space blanket', you can find where to buy a 2m x 2m square of aluminsed polyester for 84p, a company called evaQ8.
But that's all building. Scoring a dead satellite dish or two from scrap is less work.
Mon Jun 03 2013, 08:27AM
A satellite dish is a wee bit too small to be useful at 2.4GHz. They're designed for something like 10GHz.
