  • Guests: 36
Sanchez (36)
Knarvel (13)
10/16 Sanchez (36)
10/16 Knarvel (13)
school problem i cannot solve
tarakan2
Sat Jun 01 2013, 09:11PM Print
tarakan2 Registered Member #3859 Joined: Sun May 01 2011, 03:47PM
Hello
I am trying to solve for one of the catheti of the right triangle:
1 cathetus (leg) of the triangle = h*0.5*(1/phi)
2 cathetus (leg) of the triangle = h
hypotenuse of the triangle = R1
So I did some simple algebra and I got: h = (+-) 2* R1 * phi / sqrt(4* phi +1).
For some reason the cathetus 2 is greater than the hypotenuse
https://www.google.com/search?q=(440*phi)%2F((4phi%2B1)%5E0.5)&oq=(440*phi)%2F((4phi%2B1)%5E0.5)&aqs=chrome.0.57j0.25731j0&sourceid=chrome&ie=UTF-8#sugexp=cqrwrth&gs_rn=15&gs_ri=psy-ab&gs_mss=((100%5E2*4*1.6%5E2)%20%2F%20(4*phi%2B1))%5E(1%2F2)&tok=9_Zv_AxKwgDwi2cLfPW0pw&suggest=p&pq=((100%5E2*4*1.6%5E2)%20%2F%20(4*1.6%2B1))%5E(1%2F2)&cp=13&gs_id=7w&xhr=t&q=((100%5E2*4*phi%5E2)+/+(4*phi%2B1))%5E(1/2)&es_nrs=true&pf=p&newwindow=1&safe=off&biw=1280&bih=711&sclient=psy-ab&oq=((100%5E2*4*phi%5E2)+/+(4*phi%2B1))%5E(1/2)&gs_l=&pbx=1&bav=on.2,or.r_cp.r_qf.&bvm=bv.47244034,d.dmg&fp=779a49d6fdd15bbe
I did the math again to get the same result. WHY?
Help me please. I need to do some math for a golden section sheet copper cone that I will be making. If I make a mistake it will cost me hundreds of dollars.
Thank you.
Sat Jun 01 2013, 09:16PM
Draw us a picture so we can see the geometrical problem you're trying to solve. (Or so you can see the contradiction.)
tarakan2
Sat Jun 01 2013, 09:32PM
Here is the triangle.
1370122330 3859 FT154514 Cone 1
Sat Jun 01 2013, 09:48PM
It is 4p^2 + 1
You have 4p + 1 in the denominator
tarakan2
Sat Jun 01 2013, 11:43PM
THANK YOU very much
