  • Guests: 74
Inducktion (32)
Standa (31)
nabzim (33)
12/23 David (39)
12/25 Kolas (18)
dual timing circuit
Fri May 31 2013, 10:39PM Print
I asked this a while ago. I need a circuit to run a 120 second clock on one limb. Every 120 seconds it will toggle between an on/off state. The second counter will start 90 seconds into the first counter and also run for 120 seconds and do the same. I may need to very the counting range.
I've looked at pre-built timing circuits, but nothing seems adequate so I will build one. Is it easier to go with a 555 type design and use decade counters, or should I use a microprocessor like an Arduino to run the cycles?
Tetris
Fri May 31 2013, 11:07PM
I assume Arduino would be the most concise way, 555 the cheapest way, and logic.... er... go with the 555.
Ben Solon
Fri May 31 2013, 11:10PM
Microcontrollers can be very accurate when you count off increments of something like one second when using the 16 bit timer/counter and you use a high frequency accurate crystal. Beyond that, you can just do a code counter to count the number of seconds passed, then another to change the state of the pin after the desired increment. I'd chose that over some rc based timer any day.
Carbon_Rod
Sat Jun 01 2013, 01:42AM
MPLabX (free C compiler), PicKit3, and a pic12f683
1% clock drift for internal 8MHz source.... or around $1.53 a chip with no parts...
Mon Jun 03 2013, 10:49PM
I have the atmega328 running the program now. I'm thinking about adding a 3 digit counter to display the count-down. I can use the 328 to run the abcdefg segments and multiplex the three digits.
This is the lcd display I'm thinking of using:
Since it has the inputs for all three digits I figure I will have to use AND gates (or NOR if I'm using LOW to light the segment) on all segment inputs so I can control which digit I hit. I have seven digital outputs for the segments and I can use three more to control which segment I light. Does this sound reasonable?
Mon Jun 03 2013, 11:24PM
ASHPoD wrote ...
I dissagree, the 555 timers + components + pcb space would cost alot more,
look at this:
Ive got a few of these for projects, i just take the chip out of my normal ardiuno, connect the pins, program it and hook it upto power, done.
