  • Guests: 35
Will T (16)
william L (29)
Tipiment (62)
12/17 Ben7 (29)
12/18 Skywarrior (52)
12/18 Dark Horse (54)
HV DAC +-2KV
Linas
Thu May 30 2013, 05:43PM Print
Hello, i have some project coming up, and i need 16b HV power supply, capable to change voltage at least at 100KHz
(For pockels cell, so it's like 5-10pF capacitive load)
Any one know how to do it ?
For now i thinking about H bridge from two class A amplifiers, but can i do better ?
Thu May 30 2013, 06:22PM
how big can it be max?
ive got a few ideas:
Small flyback transformer @ 100Khz
some sort of boost converter?
Linas
Thu May 30 2013, 06:26PM
__=|(:3)-|--{__ wrote ...
Too slow, need something fast and low noise. Size is not a concern
Thu May 30 2013, 06:31PM
The guys I'm currently working for have another team trying to build an agile SMPS that can do +-15kV peak at up to 1kHz. They've been at it for a while and there has been a fair amount of magic smoke.
I'd use two vacuum tubes like the 811, 572B, GU81M, 833 or 4PR1000A, connected as a White cathode follower. Wireless filament power for the high-side (ask Marko :) )
You could either run it off 4kV, or build two copies and drive them 180 degrees out of phase.
Linas
Thu May 30 2013, 06:40PM
Steve Conner wrote ...
I get SiC JFET 1700V 0.5R, well, i could drive them at 1600V, so that would be +-1.6KV peak,
Is it hard to cascade JFET's ? if i use two in series, it will give me what i need
Thu May 30 2013, 08:04PM
I have no idea. The Art Of Electronics shows a series MOSFET stack that could be adapted, but I expect it would have serious problems maintaining even voltage sharing at high frequencies.
Thu May 30 2013, 08:36PM
Just a quick sanity check ....
2kV pk @ 100kHz across 10pF = 6.28 A pk .....
Is what you are aiming for something like this ? Link2
but faster ?
must the switching be pulse/squarewave ?
e.g. fixed frequecy sinewave would be so much easier.
Linas
Thu May 30 2013, 09:10PM
Sulaiman wrote ...
I am developing feedback loop with pockels cell. in real life i will have small voltage changes, like 100-200V,
I have to control dispersion from PID loop, that it,so i need to have few kv range
while surfing in scientific literature i found that for my task i only need +-1Kv, so 1700V JFETS should do the trick
Antonio
Fri May 31 2013, 12:45AM
A 10 pF capacitor at 100 kHz has an impedance of 1/(2*Pi*100000*10e-12)= 159e3 ohms. 2 kV over this results in 12.6 mA. Still not easy, but possible.
Linas
Fri May 31 2013, 07:32AM
Antonio wrote ...
Well, idea is this. since JFET will be driven in different phase, total load always will be the same, and equal 20W. this is good for DC power supply, since it will not get into step response and kill my JFET's
1369985400 1143 FT154427 Untitled
Now, how to get clean 20W 1,5KV power supply, i don't think that simple push-pull will be low noise ?
Idea use resonant converter with full wave bridge rectifier, and current regulator for that converter which connects to HV DC output and regulate current for resonant circuitry.
