  • Guests: 40
Sonic (59)
kamelryttarn (47)
11/30 arnsfelt (46)
11/30 jaysun92 (33)
12/02 Hax (40)
Microwave hacking
Tue May 28 2013, 06:24AM Print
Hi all.
I am looking into modifying a domestic or industrial (higher power = useful) microwave so that it can be used as a poor man's
kiln when the inside surface is replaced with a multilayer insulator such as fire cement.
A useful addition would be to remove the useless rotation motor and put the K type thermocouple through the resulting
hole in the base plate with some sort of RF feedthrough so microwaves can't leak out.
Yes I have a leakage tester smile
A while back one of my experiments used a microwave with a B/W video camera placed over an existing hole in the top casing, so that it could be used to see inside the cavity during operation without the door getting in the way.
Has anyone done anything like this?
Note, using an inverter would make things a lot simpler, as these can be precisely controlled and power feedback is a lot easier when digital signals are used rather than old fashioned relays.
See Link2
And Link2
Also Link2
Also relevant as I have one of these inverters, Link2
-A
Tue May 28 2013, 05:45PM
Please let us know how it goes.
I think it'll work best if you keep the heated volume much smaller than the cooker box.
Perhaps cut a cavity in a block of low density firebrick.
What refractory material will you use to absorb the microwave energy?
I have to fault the Hackaday page
for saying "smelting metal" when they really mean melting metal. Link2
johnf
Tue May 28 2013, 08:02PM
Conumdrum
I have hacked several inverter uWaves for high temp chemical reaction chambers @ work.
The opto isolators one each direction are for control. For the in direction to the power module.
this runs at around 200 hz with the mark space ratio being directly related to power output.
You cannot go below 30% power as there is not enough heat in the filament below this for reliable operation. For powers lower than 30% the control pcb starts turning the oven on and off just like convenional ovens.
The other opto changes state when the inverter output is true.
I used a small micro PWM output pin to control the power pcb
A good crucible would be silicon carbide or tungsten carbide both soak up uwaves very well
Tue May 28 2013, 11:15PM
Ive been wanting to try hack some of the inverters, is there any place to buy a few cheap?
Ash Small
Wed May 29 2013, 05:58PM
Hacking microwave oven inverters isn't easy. I looked into it a while back. There is an old thread here somewhere. You need some form of protection to prevent transients in the mains from causing voltage peaks that destroy the IGBT. There are other issues as well, I'll see if I can find a l;ink later.
