  • Guests: 48
01/18 Noelle (43)
01/18 King_of_Junk (36)
01/18 Ixz (35)
Programming the sn9c10x webcam chipset
WaveRider
Wed Aug 30 2006, 05:20PM Print
I am interested in interfacing a webcam to a microcontroller for use in remote surveillance (mountaintop weather stations, high altitude meteorological balloons, etc.)
The problem is I would like the u-controller and the camera module to talk to each other enough to take a still snapshot every few seconds or so (30fps video is not really needed..and my radio link doesn't have enuf bandwidth anyway..)
I would like to find an extensive datasheet or a good application note outlining how to talk to this device... I feel a bit overwhelmed at the possibility of having to reverse engineer a linux driver.. Does anybody have any suggestions? Google does not yield much useful info...however, you all may have some links that I missed!
Thanks!
Nucleophobe
Wed Aug 30 2006, 08:05PM
Nucleophobe Registered Member #108 Joined: Thu Feb 09 2006, 11:44PM
I also wanted to do a project like that but never got the guts up to dive in. confused If you need, I have an extra sn9c10x based webcam, striped down to the components.
Have you played around with the cam in Linux much? I had problems with the drivers, and my computer would occasionally reboot when using them.
I found this on Sonix website: www.sonix.com
Good Luck!
Carbon_Rod
Thu Aug 31 2006, 05:34AM
webcam API in windows (or pocket PC) is super easy.
Low resolution mini-camera from cell phone (AVR soucre):
$20 + $7 hobby DIP adapter
WaveRider
Thu Aug 31 2006, 01:17PM
Thanks for the messages guys!
I have been playing around with a QWare Easycam. I am using Linux kernel 2.4 on my PC.. The driver only works on kernel 2.6...(In fact, the driver is already installed in version 2.6) I am procrastinating with an upgrade...too many other things to do..
I went to the Sonix website and registered..hopefully within a couple of days, I will be able to download docs that are a bit more useful than the marketing blurbs found on their guest site..
I'll let you know how it goes.....
EDIT 20060901:
Found a datasheet on SourceForge. Gives command set.. I think I'll have a more detailed look at the linux driver to understand the use of the commands. The microcontroller has some basic USB libraries, so I will not have to write them from scratch, but I am trying to understand the protocol better (this site is interesting and informative...
