  • Guests: 49
A few VTTC Questions
M.A.D.
Sat May 25 2013, 01:04PM Print
M.A.D. Registered Member #4052 Joined: Thu Aug 11 2011, 04:43AM
Hello,
I have just started building a tube coil and have a few questions.
How does one determine the proper grid leak values, is there a formula of some sort? I assume that The grid leak values are in some way related to the frequency of the coil, however I have not been able to find anything specific.
Also, can a wirewound resistor be used as the grid leak resistor, They are much easier to find at high powers, but I am wondering if their inherent inductance would be a problem.
Sat May 25 2013, 05:12PM
You should read Steve Wards excellent VTTC FAQ and chapter 4 will explain about the grid leak. Link2
Sat May 25 2013, 06:58PM
Hi,
first you need to know the negative grid voltage for your tube, this can also be obtained from the constant current characteristics but it is not so simple. For usual directly heated triodes, the negative grid voltage is a few hundred Volts (300~500 V usually).
Then you need to know the plate current and the "current amplification factor" of the tube (this can also be obtained from the constant current characteristics), usually it is around 5-15, you can use 10 for the first guess. Then you divide the plate current by this amplification factor and you get the grid current.
R_leak = Vgrid / Igrid
The RC time constant needs to be longer than one HF cycle, but not too long.
