  • Guests: 31
marko666 (58)
12/16 Will T (16)
12/16 william L (29)
12/16 Tipiment (62)
PIR sensor fun
G^3
Wed May 22 2013, 08:22AM Print
G^3 Registered Member #97 Joined: Thu Feb 09 2006, 05:40PM
I took a PIR sensor ( PIR d203b datasheet ) from an motion sensor switch and I have been goofing around with it. I hooked it up as follows: Drain to +5V, ground to ground, and source to DMV with a 1M ohm resistor from source to ground. After turning on the power it takes a while to settle to around .91 V or so. If I put something kinda warm infront of the sensor, like my hand, it drops about a tenth of a volt or so and the returns back to near .91V. When I remove my hand the voltage goes up a similar amount before return to the steady state. Something really hot makes a larger increase.
I have a few questions:
1. What is the purpose of the resistor between the source and ground (the datasheet circuits all have a 47K ohm resistor)
2. Why does the voltage change and then return to the steady state? It is still looking at the hot thing?
It is kinda fun. You can point it at things and tell if they are really hot or not... very useful
Thanks
Wed May 22 2013, 10:39AM
If you get hold of a cheap make-up/shaving magnifying mirror, - a few £ on ebay - and set your sensor up at its focus, as in a reflecting telescope, you'll be surprised at the increase in range and sensitivity.
Wed May 22 2013, 11:20AM
1. Don't know tongue
2. The sensor contains two sensing elements in a voltage divider configuration. The output is the difference between them.
Fri May 24 2013, 05:24AM
An even more interesting hack is to make a "Chopper" using a pager motor with its weight replaced with a vane.
This will when correctly RPM adjusted allow you to make an effective linear PIR sensor.
I would expect around 3-400 rpm from such a setup, those cheap "heat vision" scopes often use something like this or the electronics variant of pulsing the power supply to help compensate for a lousy sensor.
I am in the process of seeing if this works with LCD panels taken from broken PS3 optics, as they are easy to find and a heck of a lot lower power.
-A
Fri May 24 2013, 02:27PM
I just thought of a possible explanation for the 47k resistor. The sensor might have a FET source follower built in to buffer it, like an electret mic. The 47k resistor would be needed to bias the FET.
The chopper idea would certainly work.
Fri May 24 2013, 06:52PM
But would the ps3 optics idea work?
Does anyone have the pinout for those small screens?
-A
hboy007
Sat May 25 2013, 08:24AM
Conundrum wrote ...
It won't. The long-pass filter of the detector flattens everything shorter than 5500nm to zero. Even if the optics were made of fused silica, the optical window would be limited to <4000nm.
One of the few things that might work is the MEMS mirror array of a DLP projector embedded in some fancy infrared optics system.
But then again, you might also consider such contraptions: Link2
Mon May 27 2013, 05:35PM
As it happens I have a broken DLP unit here, which might be useable.
The problem is that the power supply is history, so there is no way to figure out the voltages.
The service manual didn't mention anything helpful..
-A
