  • Guests: 57
CT2 (37)
Josh Johnson (46)
01/21 Banana Man (41)
01/21 TheAnomaly (13)
01/23 GimpyJoe (36)
sstc questions
teslarevolution
Mon May 20 2013, 01:11AM Print
teslarevolution Registered Member #16903 Joined: Thu May 09 2013, 08:00PM
Hello I am working on a sstc build based off of steve ward's micro sstc but I want to make it "sing" using a polyphonic pic interrupter by replacing his 555-based interrupter with the pic version and replacing the tc4420 with a tc4421 driver and lastly the actual MOSFET from a irfp460 with a stw88n65m5 which is rated at 650V at 84A so if I made these changes but keep everything else the same will it work?
pic interrupter will be attached
any help would be appreciated
MicroSSTCschematic2
1369012235 16903 FT0 Get
