  • Guests: 54
09/16 Michael Witt (36)
09/16 AleSeg (15)
09/17 Jyardana (41)
High Intensity Warning Piezo...
Mon May 13 2013, 04:04PM Print
i have taken apart two radio shack piezo speakers. these will be used to warn the human pilot that the battery is first at 50% and then at "20% land now" warnings. one is 102dB the othe 105dB, there are tiny circuit boards on both.
the problem: they are to big and heavy as manufactured.
the solution: take out the piezo component and run my own AC tone through it, via external SMT circuits.
My question: isn't it just an HF AC wave that the piezos' need? it seems I can choose several frequencies through my own wave generation circuits, right? is pulsing DC less effective that AC ?
pics to follow:
1368461070 2431 FT0 Tone1
1368461070 2431 FT0 Tone2
Mon May 13 2013, 06:06PM
Best to drive at acoustic resonance for max. output.
I've noticed that this can vary with temperature, so a self resonant single transistor circuit would be best here.
2Spoons
Mon May 13 2013, 10:04PM
If you want high sound pressure (~100dB) out of a piezo disc it needs to be mounted in a Helmholtz resonator. I've been down this path before - without the resonator you will get little more than a squeak out of your piezo.
Tue May 14 2013, 02:46AM
2Spoons wrote ...
ok, fair enuff, let me look up "helmholtz resonator" , but please elaborate more...
Electroholic
Tue May 14 2013, 03:09AM
Both of the about, and I think you will find square waves louder than sine waves. Easiest tho is to probe the original circuit and try month mimic the waveform/frequench.
Tue May 14 2013, 03:15AM
it looks like they both have the plastic "resonators" built in...
[it also looks like they both use a three terminal inductor, possibly an auto-transformer, for voltage/impedance reasons..]
in the below oscillogrram I put in a 9v, measured 97 V across the piezo wires (V-pk-pk) so im certain now its a 1:10 Auto Tmfr... also the period is 320uS, which means 3,125 Hz, so right down the middle of what the specs claim...
heres one:
1368501331 2431 FT153791 Tone3
1368501331 2431 FT153791 Tone4
pics on piezo warbler :
1368504514 2431 FT1630 Warble
Wed May 15 2013, 04:13PM
if the resonator was meant for 3kHz, can I use 7kHz and still have it be reasonably loud (60-80% of the 3kHz loudness?) id like to have several frequencies, and warble patterns for emergency purposes. so maybe 3kHz, 5kHz and 7kHz, im thinking. or is that Helmholtz resonator a tuning device as well?
id also like to use a 555 timer and a H-bridge to drive the autotransformer/piezo. Im hoping to sink one pair, then source the other pair out of pin 3 to provide the alternating waveform.
heres two vids :
2Spoons
Wed May 15 2013, 10:04PM
Usually the resonator will be matched to the mechanical resonance of the piezo disc, as thats where the highest sound pressure can be obtained. You are unlikely to get anywhere as loud output off-resonance, but I'd suggest doing a sweep as there are probably other frequency peaks.
Thu May 16 2013, 12:11AM
2Spoons wrote ...
yes that was what I was worried about, I was hoping it would be a broad-band pass instead of a narrow pass type, ,but I guess ill sweep it to find out. ill try to put a schematic together for the 555 timer source sink driver.
Thu May 16 2013, 05:03PM
Note: the transformer can also be part of the resonance-circuit.
The piezo disc works as a cap, the the transformer as inductor.
