  • Guests: 51
Mini 811a VTTC , Mians Sycned Interrupted
TwirlyWhirly555
Sat May 11 2013, 04:19PM Print
TwirlyWhirly555 Registered Member #4104 Joined: Fri Sept 23 2011, 06:54PM
Hey ,
Wanted to post my progress on my 811a VTTC ,
Just got around to making a interrupter that is synced to the 50 hz mains :)
50 Hz @ 9 Volts is rectified to 100 Hz , then a transistor pair is used to produce a 100 Hz square wave that is then fed into a 4017 , the output from the 4017 is 10% duty cycle at 10 hz this is used to drive a 600 volt triac in the cathode of the 811a .
Primary - 32 turns
Tank - 750 pF ( 2 1.5nF caps in series )
Secondary - 2" x 2.5"
Feedback - 12 Turns
Feedback resistor - 25W lamp
Supply - level shifted Mot , 4uF of capacitor on shifter .
The output I got was 9" Arcs from the secondary at 10 hz rep rate .
8727985213 0a8eae8672 C
SAM_1003 by TwirlyWhirly555, on Flickr
8727982787 2137ce352d C
SAM_1006 by TwirlyWhirly555, on Flickr
Videos - Link2 Link2
I have made a new secondary that is 2.5" x 5.5" with around 4 ish " of windings .
Tank Cap is 1.5 nF , Primary 3" with 30 turns , 14 Feedback , rest remains the same values . Running at 10 Hz rep I get 10" arcs , but I think I could get abit more from it but im at the limits of the 811a now as with the new secondary it getting very red so I plan to tune more then move to a 572B tube instead .
Im not sure if I should mess with the feedback setup as im getting good output but think I could get more hopefully
8729184228 Ed0bd8b15c C
SAM_1012 by TwirlyWhirly555, on Flickr
Getting there :D
Twirly
Sat May 11 2013, 06:12PM
Beautiful coil! Love those arcs!!!!
teravolt
Sun May 12 2013, 03:02PM
Hi TwirlyWhirly555 nice picturs, how many turns do you think you have on your secondary and what do think the resonant frequency is?
TwirlyWhirly555
Mon May 13 2013, 03:13PM
EasternVoltageResearch - thanks :) , Was happy to get the output I did from a small secondary .
teravolt - Thanks :) , I don't have any idea on the number of turns , but resonance of the secondary is around 550 KHz I believe .
2.5" by 5" secondary with GU81M , Outputs 12" ish @ 10 Hz mains synced interrupted
8735898196 510bd0656d C
SAM_1042 by TwirlyWhirly555, on Flickr
teravolt
Tue May 14 2013, 04:15AM
Is this your 811
TwirlyWhirly555
Tue May 14 2013, 08:58AM
teravolt wrote ...
Is this your 811
1368504938 195 FT153759 811
That's a 100 W tungsten lamp that's been used as a grid leak resistor , in the 3rd picture in the 1st post you can see the 811a tube laying on its side in the bottom left hand corner just in front of the MOT .
