  • Guests: 53
01/23 GimpyJoe (36)
01/24 OnFire (64)
01/25 Evgenij (60)
howabout 1 gigohm carbon comp resistors.
Microwatt
Tue May 07 2013, 04:32PM Print
Microwatt Registered Member #3282 Joined: Wed Oct 06 2010, 05:01PM
selling them for 5 bucks each. 2.00 shipping flat rate
1367944300 3282 FT0 Capture
Tue May 07 2013, 07:48PM
Ain't seen them before.
From your picture I can't tell the size,
which goes with the power rating in most resistors. Of course at such a high R value, the nominal power rating is just a size indicator.
Do you know if the voltage rating is typical of the size? Perhaps 300 or 350 or 500 volts?
Microwatt
Tue May 07 2013, 09:12PM
it looks like a 1/2 watt resistor. body is about 3/8 inch.
Tue May 21 2013, 10:10PM
Handy for HV monitoring, you can make a good voltmeter with them.
