  • Guests: 61
Recycling BUL38Ds
Tue May 07 2013, 05:21AM Print
Hi all.
Just found two pairs of BUL38D transistors from a couple of non working cracked glass induction cookers.
Is there any hope I can make a 70kHz coil with them or is it a lost cause?
They test fine and are likely suitable for 150V operation.
Thanks!
-A
Tue May 07 2013, 10:16AM
Hi, I think you can, but driving bipolar transistors is a nightmare. You can try some kind of self-excited series resonant circuit like it is done in CFLs, then you basically make a very low power DRSSTC with them.
Ben Solon
Wed May 08 2013, 01:36AM
ATX power supplies would be a good place to look for reference. IIRC they use a type of current mode base drive transformers. I think that sticking with the half bridge topology would be ideal.
Wed May 08 2013, 09:35AM
I'm afraid that hard switching bipolars will not work at TC frequencies. At 70 kHz it might still do something, but resonant switching should be much better and is easily achievable with bipolars using the self-excited circuit (current mode base drive transformer, with feedback from the output)
Fri May 10 2013, 06:10PM
Thanks for the info guys, I will give this a try.
-A
