  • Guests: 66
I can not get this little coil working.
Patric
Mon May 06 2013, 06:45PM Print
Patric Registered Member #2899 Joined: Wed Jun 02 2010, 06:31PM
With the 811a and a 10 nF cap and classic circuit (I build several of them) but this time with a little coil it won't work! I think it is the coils, but what can I do? Help!
1367865891 2899 FT0 1
1367865891 2899 FT0 2
Inducktion
Tue May 07 2013, 04:44AM
Well, I may not know much about TC's but I'd shorten those leads on those caps hanging out there quite a bit.
Also, tried reversing the coils? Maybe the phase is messed up or something.
Tue May 07 2013, 05:14AM
Yes, check the phasing.
Also check that the tube isn't damaged, it should NOT glow blue unless being severely taxed.
A little glow is OK but bright blue means it could be gassy.
Patric
Tue May 07 2013, 08:00AM
Thank you, but I made several coils, so I have some experience. I did reverse a coil (several times) and the tube is perfect.
Tue May 07 2013, 10:11AM
Hi, you really do have 10 nF of capacitance there? Way too much, go for something like 1 nF, RF ceramic for the best result but a string of MKP/FKP caps works too.
The obligatory question: Did you calculate the resonances and tune the coil with primary taps?
Edit: What is the supply voltage?
Patric
Tue May 07 2013, 02:50PM
Dr. Dark Current wrote ...
I can not go lower than 10 nF, I have 5 47 nF capacitors, it is a surplus... And I did the calculation, but have no taps on the coil. The supply voltage is 1200V DC.
Tue May 07 2013, 05:37PM
Well, for 1.2 kV 10nF might be tolerable, still too much, but the coil should work anyway. Make the primary coil tappable, when a VTTC is out of tune, the output can be almost none.
What kind or type are the capacitors?
Patric
Tue May 07 2013, 10:05PM
47nf 3000V, those white-ones. Thank you, I will try to tune again...
Wed May 08 2013, 09:18AM
Well you must use polypropylene capacitors in the tank circuit, any others will just sit there and heat up with little output frown
